Local Time 15:10 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CM2: DIM bit
     Page 1 of 4
bar1010
Posted: 05:09pm 18 Sep 2020
Wouldn’t it be nice if we had DIM bit functionality to minimize the amount of storage needed
for a variable with two values?
It would require eight times less space than a string with length 1.
Edited 2020-09-19 03:32 by bar1010
Posted: 05:30pm 18 Sep 2020
I think the question will be "How many more than 512K bytes do you need?"
twofingers
Posted: 05:49pm 18 Sep 2020
Hi bar0101,
IMHO the best (only?) way to implement such functionality would be to use integers and a bunch of Functions or CSubs (better CFunctions if they existed). I did something similar in my Game Of Life ... but not consistently (because I upgraded an existing program).
Good luck!
Michael
RetroJoe
  lizby said  I think the question will be "How many more than 512K bytes do you need?"
Well, as we know from Bill Gates, no-one will ever need more than 640K
Edited 2020-09-19 03:51 by jpusztai
Enjoy Every Sandwich / Joe P.
Posted: 05:56pm 18 Sep 2020
  twofingers said  IMHO the best (only?) way to implement such functionality would be to use integers and a bunch of Functions or CSubs (better CFunctions if they existed).
CaptainBoing is ahead of us with that: bit manipulation
twofingers
Posted: 06:11pm 18 Sep 2020
sounds like:
  Quote  640 kB ought to be enough for anybody. (maybe Bill Gates?)
@lizby
Sometimes you have to handle more than 512KB of data and a smaller amount of data is generally faster to copy, manipulate, move, and store.
Kind regards
Michael
EDIT. jpusztai was faster (640KB).
@lizby: Thanks for the bit manipulation link!
Edited 2020-09-19 04:15 by twofingers
RetroJoe
Posted: 06:12pm 18 Sep 2020
Cool!
I am using events in my project (an arcade game with things like “IF event.fire = 1”), so can someone opine on the “speed vs storage” using the Captain’s FLAGS method? I anticipate I will need to manage 30 or so events, and it seems the setting and getting of FLAG bits is slower than comparing actual variables, but I could be wrong.
P.S. I sense an MMBasic enhancement request for Boolean variables in 3, 2, 1...
twofingers
Posted: 06:28pm 18 Sep 2020
@Joe
I would use integers as flags with the current MMBasic version. At least if you want to check only individual flags, no sets of flags with a bit pattern mask
Posted: 06:43pm 18 Sep 2020
You have 5 MB or variable memory (512K of program memory), so I wouldn't be prematurely optimising for size. Performance wise I definitely wouldn't be bit twiddling in your main loop if you have an alternative.
Posted: 06:48pm 18 Sep 2020
  twofingers said  Sometimes you have to handle more than 512KB of data and a smaller amount of data is generally faster to copy, manipulate, move, and store.
And you have enough hundreds of flags for it to make a difference? I'm just wondering about a use case for the CMM2.
I believe in another thread CaptainBoing said that his experimentation had determined that the bit manipulation routines were slower than just using integers, but it hurt his sense of efficiency to be "wasting" all those bits.
Having started in a time when programmers were cheap ($5 an hour for my first full-time job) and computers were expensive ($100 a minute), I can't say how many "efficiencies" I've given up as the price per cycle and per bit has plummeted.
bar1010
Posted: 07:14pm 18 Sep 2020
I had in mind using a multi-dimensional array of bits.  For example, a binary image.
Edited 2020-09-19 05:19 by bar1010
twofingers
Posted: 07:32pm 18 Sep 2020
Note: I never said it would be a solution for flags!
  twofingers said  @Joe
BTW. CaptainBoings functions are not the optimum.
Faster than (bit set)
a=a or (2^63)
is this
a=a or (1<<63)
Faster than (bit reset)
a=(a OR (2^63)) XOR (2^63)
is this
a=a AND inv (1<<63)
Maybe CaptainBoing can update the Wiki?
Michael
bar1010
Posted: 07:37pm 18 Sep 2020
  thwill said  You have 5 MB or variable memory (512K of program memory), so I wouldn't be prematurely optimising for size. Performance wise I definitely wouldn't be bit twiddling in your main loop if you have an alternative.
If we have 5 MB of variable memory, why do I receive Error: Not enough heap memory
with the statement dim string test$(137,137,137) length 1?  Shouldn’t this allocation require
2,571,353 bytes and thereby fit within 5MB?
RetroJoe
Posted: 07:40pm 18 Sep 2020
Thanks, guys, for confirming - I will stick with honest-to-goodness variables, but having grown up in a “memory is scarce” era, I guess we all have the same guilt pangs of wasteful storage. The overhead of any compression scheme is quite significant, and I certainly will not be needing it. I also like the idea that a “bit is a bit” I.e. there is a degree of code validation if a logical Boolean value is guaranteed to have only one of two states I.e. preventing coding, coercion or rounding that makes 1 not quite equal to 1.
FYI, I just worked on a project where we had to provision 8 TB, with a “tee”, of RAM on a server. I’m thinking that much RAM did not exist on the entire planet until quite recently :) Initially, I kept writing “8 GB” in my emails until I got the exponent value right :)
And, regarding scarce resources and the inversion of labour to hardware costs, check out this video on the fabrication of the “rope memory” (ROM) used in the AGC (Apollo Guidance Computer). Forget about the costs - can you imagine working on a project like this, where the “build” takes months, and debugging is a nightmare?? I thought burning and UV erasing EPROMs was a tedious process...  but this is insane!
If you’re interested, there is a multipart YT of a team of computer historian fanatics that have restored an AGC to working order, including recreating the development tool chain, writing emulators for the AGC, and OCRing the archived printout of source code - amazing stuff.
twofingers
Posted: 07:44pm 18 Sep 2020
  bar1010 said  If we have 5 MB of variable memory, why do I receive Error: Not enough heap memory with the statement dim string test$(137,137,137) length 1?  Shouldn’t this allocation require  2,571,353 bytes and thereby fit within 5MB?
Each of your strings uses 2 bytes (length byte + 1).
Posted: 07:50pm 18 Sep 2020
  twofingers said  Note: I never said it would be a solution for flags!
Fair enough. What is the use case?
twofingers
Posted: 07:51pm 18 Sep 2020
  jpusztai said  [...] but having grown up in a “memory is scarce” era, I guess we all have the same guilt pangs of wasteful storage. [...]
I think that's true for many here.
bar1010
Posted: 07:54pm 18 Sep 2020
Binary images
Posted: 07:58pm 18 Sep 2020
  jpusztai said  I also like the idea that a “bit is a bit” I.e. there is a degree of code validation if a logical Boolean value is guaranteed to have only one of two states I.e. preventing coding, coercion or rounding that makes 1 not quite equal to 1.
Then use some functions to make it so.
They'll run much slower than using inline code of course, but that's a normal speed/size tradeoff.
Posted: 08:02pm 18 Sep 2020
Binary images
I'd need more elaboration to understand what needs to be done with these binary images that cannot now effectively be done (and the necessary time scale).
     Page 1 of 4
