Local Time 20:58 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Archiving dirs for easy transfer over serial
epsilon
Posted: 10:19am 18 Sep 2020
Hi all,
I made a pair of tools, mac.bas and max.bas, that allow you to roll up (and extract) a directory tree into a single file archive.
The archive can then easily transferred over serial using XMODEM.
I don't like the idea of swapping SD cards in and out all the time. The motivation for archiving is to allow easy transfer of software packages over serial instead.
mac.bas and max.bas work on Color Maximite2 and on PC.
Details below. Comments are very welcome. Maybe there are already better tools available that allow you to do something like this?
This is my first MMBasic program so feedback on the source code is welcome too.
Cheers,
Epsilon.
mar.zip
mac/max Color Maximite 2 Archiving Tool by Epsilon
Version 0.1
Mac.bas allows you to roll up a directory tree into a single file archive.
The created archive has the same name as the given directory, with a .mar extension.
Max.bas allows you to unpack a .mar archive, creating a directory tree with the same name as the given archive, without the .mar extension.
Mac.bas and Max.bas work both on PC and on Color Maximite 2, so you can download a package on your PC (e.g. Mauro's psgmini_cmm2 demo), archive it on PC using mac.bas, transfer it over to your CMM2 using XMODEM, and unpack the archive on your CMM2 using max.bas.
Example 1: Creating a .mar archive on CMM2
> list files
A:/
  <DIR>  bak
  <DIR>  psgmini_cmm2
10:47 18-09-2020       7847  mac.bas
09:23 18-09-2020       9216  max.bas
3 directories, 13 files
> *mac psgmini_cmm2
Create Maximite Archive 0.1 by Epsilon
 Processing dir psgmini_cmm2
 Processing file .gitattributes
 Processing file psgdemo.bas
 Processing file psgmini.inc
 Processing file README.md
   Processing dir ASSETS
   Processing file ALESTE.VGM
Done.
> list files
A:/
  <DIR>  bak
  <DIR>  psgmini_cmm2
11:08 18-09-2020     878068  psgmini_cmm2.mar
Example 2:Extracting a .mar archive on CMM2
> list files
A:/
  <DIR>  bak
> *max psgmini_cmm2.mar
Extract Maximite Archive 0.1 by Epsilon
 mkdir psgmini_cmm2
 mkdir ASSETS
Processing file ALEXKIDD.VGM
Processing file AWESOME.vgm
Processing file BATTLETOADS2.VGM
Processing file BEAST1.vgm
End of archive reached.
Done.
> list files
A:/
  <DIR>  bak
  <DIR>  psgmini_cmm2
Example 3: Creating a .mar archive on PC
c:\cmm2\mar>dir
Volume in drive C is OS
Volume Serial Number is 8497-A711
Directory of c:\cmm2\mar
09/18/2020  12:04 PM    <DIR>          .
09/18/2020  12:04 PM    <DIR>          ..
09/18/2020  10:48 AM             7,845 mac.bas
09/18/2020  12:02 PM             2,365 mac_max.readme
09/17/2020  10:11 PM             9,178 max.bas
09/18/2020  12:04 PM                 0 ntsh.temp
09/18/2020  12:04 PM    <DIR>          psgmini_cmm2
              5 File(s)        897,456 bytes
              3 Dir(s)  101,267,017,728 bytes free
c:\cmm2\mar>..\DOS_MMBasic\MMBasic.exe mac.bas psgmini_cmm2
c:\cmm2\mar>dir
09/18/2020  12:03 PM           878,068 psgmini_cmm2.mar
Example 4: Extracting a .mar archive on PC
c:\cmm2\mar>dir
c:\cmm2\mar>..\DOS_MMBasic\MMBasic.exe max.bas psgmini_cmm2.mar
c:\cmm2\mar>dir
Epsilon CMM2 projects
twofingers
Posted: 11:27am 18 Sep 2020
Hi and welcome epsilon,
I did not yet try, but I like the idea and your code seems clear, straight forward and readable. Very good job (so far). Thanks!
Kind regards
Michael
The lone and ...
epsilon
Posted: 01:14pm 19 Sep 2020
Thanks twofingers.
I fixed some issues on the DOS side of things. See attachment.
I also created a GitHub repository, for future revisions:
https://github.com/epsilon537/mar_cmm2
/epsilon.
mar.zip
twofingers
Posted: 02:01pm 19 Sep 2020
Hi epsilon,
please check your function dirExists%(dirToProcess_l$)
I get an error if the folder exist (from MKDIR @line290/v0.2).
@line 37 is wrong
dirExists% = (DIR$(dirName$, FILE) <> "")
please use
dirExists% = (DIR$(dirName$, DIR) <> "")
Some suggestions::
I would like to ask for a new folder name if the folder exist.
and/or
If a folder exist then should we have the option to include the files.
... just some ideas ...
Michael
Edited 2020-09-20 07:08 by twofingers
The lone and ...
epsilon
Posted: 09:18am 20 Sep 2020
Hi Michael,
Now I'm confused. The 0.2 version of max.bas dirExists% looks like this:
'This function checks if given directory name already exists or not
FUNCTION dirExists%(dirName$)
 IF MM.DEVICE$ = "DOS" THEN
 ELSE
 ENDIF
END FUNCTION
i.e. it does use the DIR qualifier, not the FILE qualifier. If there would have been a FILE qualifier there instead, I can understand that you'd get an error on line 290 because the dirExists% check would fail.
Re your suggestion, I don't really like the idea of renaming, because then what you've unpacked doesn't truly reflect what's inside the archive anymore. Current behavior is to abort when it runs into an existing file or dir. Maybe that's too abrupt. I checked how unzip behaves on Windows in this case. It prompts you to skip all, to replace all, or to skip or replace on a file by file basis. Maybe I should do something like that.
/Epsilon.
twofingers
Posted: 10:45am 20 Sep 2020
  epsilon said  Hi Michael,Now I'm confused. The 0.2 version of max.bas dirExists% looks like this:
Hi Epsilon,
you are too fast. Sorry, the issue was in the v0.1. I didn't expect you fixed it so fast.
  Quote  Re your suggestion, I don't really like the idea of renaming, because then what you've unpacked doesn't truly reflect what's inside the archive anymore. Current behavior is to abort when it runs into an existing file or dir. Maybe that's too abrupt. I checked how unzip behaves on Windows in this case. It prompts you to skip all, to replace all, or to skip or replace on a file by file basis. Maybe I should do something like that.
/Epsilon.
Giving the new folder a new name if the old folder exists is just an idea. I think I will realize that for myself.
Michael
The lone and ...
twofingers
Posted: 01:06pm 22 Sep 2020
Hi epsilon,
Some feedback ...
I have to report a little issue regarding "mac.bas" v0.2 for DOS:
Your code does not tolerate path names with spaces (e.g. "D: mar folder /") if I start MMBASIC from there.
eg:
D:mar folder/ (includes MMBASIC.exe and "mar.bas")
D:mar folder/testfolder (is the folder to archivate)
  Quote  [85] Open refFile$ For INPUT As #3
Error: No such file or directory
When I start from "D:/marfolder/", I don't get an error message.
I would suggest deleting the temporary file ("ntsh.temp") after the program has run.
A friendly question:
May I distribute your MAR.ZIP with my contributions if I use it?
And again: Thanks!
Michael
The lone and ...
epsilon
Posted: 09:33am 23 Sep 2020
Hi Michael,
Thank you for the good feedback! I fixed the issues you reported in V0.3, now on GitHub:
Feel free to distribute mar.zip as much as you want. However, if you're going to make changes to the tool, I would prefer if you rename it so people can distinguish between your version and mine.
Cheers,
Epsilon.
twofingers
Posted: 10:58am 24 Sep 2020
Hi epsilon,
the extraction program is now working as expected, perfect!
I think the MAR program is a candidate for the "Welcome Tape".
MAR stands for Maximite ARchiver?
Thanks a lot.
Kind regards
Michael
The lone and ...
Posted: 12:25pm 24 Sep 2020
  twofingers said  I think the MAR program is a candidate for the "Welcome Tape".
My vision of the "Welcome Tape" is that it will only contain programs that can sensibly launched from the menu, thus excluding command-line tools no matter how useful.
I think there is definitely room to compile a distribution of "Tools" as well, it's just not something that I am willing (or have the time) to take on.
In my opinion as a community we have a growing "problem" in that a lot of great content is being created, but it gets posted to the forum and then vanishes from sight after a week or two unless the author is inclined to keep "banging the drum". For a while "capsikin" tried to keep this list on Fruit of the Shed up-to-date, but it's a largely thankless task. I don't know what the solution is, I suspect it requires two or more dedicated archivists with time on their hands ... unfortunately that isn't me.
In the meantime could I suggest that if you've created something great then you consider putting a link to it in your signature.
Edited 2020-09-24 22:28 by thwill
twofingers
Posted: 12:38pm 24 Sep 2020
  thwill said  My vision of the "Welcome Tape" is that it will only contain programs that can sensibly launched from the menu, thus excluding command-line tools no matter how useful.
Thanks Tom! I understand!
The point is that the program is extremely helpful when having a
Program consists of several parts. (e.g. Lunar Lander) IMHO.
I also don't know whether epsilon would even like that ...
Kind regards
Michael
The lone and ...
epsilon
Posted: 02:29pm 24 Sep 2020
Sure I'd like that, you know, for bragging rights
I appreciate the suggestion Michael!
But like Tom said, CMM2 needs a software repository, and that's not Welcome Tape.
I wouldn't mind using fruitoftheshed.com  as the CMM2 repository. It's a wiki. Anybody can create an account and add content. I just added a link to the MAR github page in the utilities section, next to FileBox:
http://fruitoftheshed.com/Colour%20MaxiMite%202%20(CMM2).Example-games-and-other-programs.ashx?NoRedirect=1#Utilities_8&NS=Colour%20MaxiMite%202%20(CMM2)
If a lot of people start adding content it might get messy quickly, but I think that's a good problem to have
Edited 2020-09-25 00:29 by epsilon
twofingers
Posted: 02:53pm 24 Sep 2020
Okay!
I will not continue to insist.
Michael
The lone and ...
epsilon
Posted: 02:33pm 22 Dec 2020
Hi all,
Here is a new version of MAR:
0.4:
- Combined mac.bas and max.bas into a single program, mar.bas.
- Added option to create and extract LZ1 compressed archives.
- Created an equivalent Python version, mar.py, intended for running on a host machine (Windows, MacOSX, Linux).
- DOS MMBasic version of mac.bas is no longer supported. Please use Python version instead.
Description
On CMM2, mar.bas allows you to roll up and optionally compress a directory tree into a single file archive, and vice versa.
mar.py is an equivalent Python implementation intended for running on Windows, MacOSX or Linux. This allows you to create your archive on a host machine,
transfer it over to CMM2 and unpack it there, and vice versa.
Usage
On CMM2:
 *mar c <dir> : archive directory <dir> into file <dir>.mar
 *mar cz <dir> : archive and lz1 compress directory <dir> into file <dir>.mz1
 *mar x <archive>.mar : extract <archive>.mar archive
 *mar xz <archive>.mz1 : extract <archive>.mz1 compressed archive
On Windows/MacOSX/Linux:
 python mar c <dir> : archive directory <dir> into file <dir>.mar
 python mar cz <dir> : archive and lz1 compress directory <dir> into file <dir>.mz1
 python mar x <archive>.mar : extract <archive>.mar archive
 python mar xz <archive>.mz1 : extract <archive>.mz1 compressed archive
Required CMM2 firmware version
V5.06.00
Required Python version
3.x
GitHub
mar.zip
panky
Posted: 10:28pm 22 Dec 2020
  epsilon said  Hi all,
0.4:
Disappointed to see that the MM DOS version no longer supported - have no desire to learn another language (Python) if I want to learn how your program works of play with any changes - any chance you might re-consider supporting the MM DOS Windows version?
Thanks for sharing a great program - I really like the idea behind it.
Doug.
epsilon
Posted: 09:13am 23 Dec 2020
Sorry to disappoint you Doug, but that's not going to happen. A DOS MMBasic version of mar.bas would only run on a Windows machine, so I would still have to create a Python version for MacOSX and Linux. I would end up with three different code bases to maintain.
I initially supported DOS MMBasic because I thought code re-use would make it easy, but it didn't. The platform differences between DOS and CMM2 MMBasic are significant and the DOS version is not as far along as the CMM2 version. If you look at the old mac.bas, you'll see lots of IF MM.DEVICE$ = "DOS" conditionals, introducing complexity and a source for bugs in an otherwise simple program.
Turbo46
Posted: 09:42am 23 Dec 2020
  Quote  Sorry to disappoint you Doug, but that's not going to happen.
I'm sorry too.
epsilon
Posted: 10:01am 04 Apr 2021
Hi all,
I added the option to create self-extracting archives to mar.bas:
*mar s  <dir> : archive directory <dir> into self-extracting file <dir>.mar.bas
*mar sz <dir> : archive and lz1 compress directory <dir> into self-extracting file <dir>.mz1.bas
When you execute the generated <dir>.mar.bas or <dir>.mz1.bas file, it will create directory <dir> and any subdirs and unpack itself into that directory tree.
The idea is to make it easy to publish applications consisting of multiple files (e.g. games).
As an example, I attached a self-extracting archive of the SaucerShooter demo game.
Please note that firmware version V5.07.00b23 or later is required. The code relies on the new #COMMENT START/END feature.
Cheers,
Ruben/Epsilon.
GitHub: https://github.com/epsilon537/mar_cmm2
mar.zip
SaucerShooter.mar.bas.zip
