Local Time 04:48 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CSUB Questions
chris
Posted: 09:27am 15 Sep 2020
Hello. I have some questions about CSUBs.
1) Which compiler and options do I need to use (on a Windows machine) to compile a CSUB for CMM2?
2) I see that the C header file is included in the CMM2 distribution as a public domain file, which is brilliant, but it's also stamped with the firmware version, so my question is that will any basic programs that integrate a CSUB break when ran on a CMM2 with a different firmware version, or are existing function locations "set in stone", so we can rely on forwards compatibility in the .h file?
3) If defining a CSUB that is, for example 500K, is there an overhead to parsing CSUBs in the basic parsing step that means that the true limit of CSUBS is much much lesser?
Thanks.
Posted: 09:39am 15 Sep 2020
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12289
  Quote   or are existing function locations "set in stone", so we can rely on forwards compatibility in the .h file?
Yes other than unforeseen circumstances
  Quote  If defining a CSUB that is, for example 500K, is there an overhead to parsing CSUBs in the basic parsing step that means that the true limit of CSUBS is much much lesser?
No limit other than the 512K for the combined Basic program including the CSUB definition plus the C binary
chris
Posted: 03:16pm 15 Sep 2020
Thanks.
