Local Time 15:24 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Colour bit depths - clarification
panky
Posted: 05:15am 08 Sep 2020
As I understand things -
8 bit mode is RGB332 and is 1 byte per pixel storage, and
16 bit mode is RGB565 and is 2 bytes per pixel storage
12 bit mode is ARGB4444 - is this then 3 bytes per pixel storage?
flip
Posted: 06:39am 08 Sep 2020
I suspect it should be ARGB4332. (8 bits for the colours as per 8-bit plus 16 levels of transparency) This might be an issue with the doco
Regards Phil
(EDIT: reported on 5.05.06 beta thread)
Edited 2020-09-08 16:46 by flip
Posted: 07:02am 08 Sep 2020
  Quote  12 bit mode is ARGB4444 - is this then 3 bytes per pixel storage?
4+4+4+4 = 16 /2 = 2bytes
  Quote  I suspect it should be ARGB4332. (8 bits for the colours as per 8-bit plus 16 levels of transparency) This might be an issue with the doco
Well then you would be wrong
 if(colours==12){
 pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_ARGB4444;
