Local Time 15:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Graphics in MODE 5
hitsware2
Posted: 12:06am 06 Sep 2020
circle 100,100,30
works
mode 5 ' or any # other than 1
circle 100,100,30
gives a blank screen ?
my site
vegipete
Posted: 12:49am 06 Sep 2020
Works fine for me.
Is your monitor syncing successfully?
What if you add "do:loop" so the system doesn't return to the command prompt?
edit: mode 5 pixels look very unsquare - wider than tall.
Edited 2020-09-06 10:51 by vegipete
hitsware2
Posted: 03:42am 06 Sep 2020
  vegipete said  Works fine for me.
Thank You ..
I ' m assuming the sync ...
Tried a second monitor .... Same
Loop doesn ' t help either ...
Remember .... It ' s hip to be unsquare
my site
