Local Time 15:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Undocumented (?) limit on number of items in a DATA statement
Posted: 01:24pm 05 Sep 2020
This was perplexing me whilst porting some BBC BASIC code.
Try this on for size:
Colour Maximite 2
MMBasic Version 5.05.05
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> list "test.bas"
Dim x
For i = 1 To 32
 Read x
 Print x;
Next i
Data 5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5
> run "test.bas"
Error in line 3: Syntax
The DATA line has 33 items, if you reduce it to 32 then it works.
Posted: 02:02pm 05 Sep 2020
works fine on a stock micromite
> RUN
5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
> ? mm.device$
Micromite MkII
Chopperp
Posted: 02:23pm 05 Sep 2020
Try using RESTORE first to reset the DATA pointer.
Brian
ChopperP
Posted: 02:39pm 05 Sep 2020
  Chopperp said  Try using RESTORE first to reset the DATA pointer.
Brian
RESTORE makes no difference, and it shouldn't, the DATA pointer should already be set to the first piece of data if READ has never been called.
Posted: 02:43pm 05 Sep 2020
Check the MMBasic implementation details in the manual and then split the data statement
Posted: 02:54pm 05 Sep 2020
  matherp said  Check the MMBasic implementation details in the manual and then split the data statement
Ever cryptic this section is a (relatively) recent addition to the manual and not present in the version I was referencing.
p46, Maximum number of arguments to commands that accept a variable number of arguments is 32
Thanks,
