Local Time 15:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Page down hang in "files" file manager
capsikin
Posted: 04:11am 05 Sep 2020
I've tracked down a hang I had sometimes been getting.
If I press page down in the file manager, and it can't go down a whole page, usually I can press "up" and the bottom line will be selected. But sometimes it will hang, and I can't quit with Ctrl-C or Escape.
I can avoid it by using Home and End to move to the bottom or top instead.
The hang seems to be if the folder or file path has a long name. I managed to reproduce it with something like:
mkdir "/longnamelkjshflkasjdhflksjhflaksjdhflakdhlaksjdhf"
files
Then going into the new folder and pressing page down. But I've also had it happen with shorter names if the directories are nested inside others.
edited to add: this is with version 5.05.05
Edited 2020-09-05 14:12 by capsikin
Posted: 07:34am 05 Sep 2020
Thanks - will fix in the next beta
