Local Time 04:49 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Option <foo> "Invalid in a program"
Posted: 09:11pm 03 Sep 2020
Hi folks,
I've been using a file called "config.bas" to reconfigure the CMM2's Options for a while now:
SEARCH_PATH$ = "/bin/"
s$ = Mm.Info$(Search Path)
If LCase$(Mm.CmdLine$) = "reset" Or LCase$(Mm.CmdLine$) = "clear" Then
 Print "OK"
 Option Reset
ElseIf LCase$(Mm.CmdLine$) = "list" Or s$ = SEARCH_PATH$ Then
 Option List
ElseIf Mm.CmdLine$ <> "" Then
 Error "Unknown command line option"
ElseIf s$ = "" Then
 Option F11 "chdir " + Chr$(34) + "/zmim/src" + Chr$(34) + Chr$(13) + Chr$(10)
 Option F12 "chdir " + Chr$(34) + "/sptools/src" + Chr$(34) + Chr$(13) + Chr$(10)
 Option Search Path "/magic/"
 Print "Please run *config again to complete setup"
 ' This will cause a reset
 option SD Timing Fast
ElseIf s$ = "/magic/" Then
 Option Search Path SEARCH_PATH$
 Print "OK"
 ' this will cause a reset
 Option RAM
Else
 Error "Unknown state"
EndIf
But since the release version (or possibly one of the last betas that I missed) of 5.05.05 this has reported the error "Invalid in a program" for the setting of "SD Timing" and "RAM".
Is this deliberate ?
Is there an alternative ?
On a related note, when I started my CMM2 this evening the red LED was flashing intermittently and the SD card would not read. I switched to OPTION SD TIMING CONSERVATIVE and it started working ... I then switched back to OPTION SD TIMING FAST and it was still working. Any ideas ? or was it just cosmic rays ?
Turbo46
Posted: 12:09am 04 Sep 2020
On the SD card issue, Peter Mather said here:
  Quote  For SDcards that don't work it appears the issue is in initialisation. Once they have been initialised once successfully using the conservative timings, and assuming they are not removed or power cycled, then they can be re-initialised with the normal timings and will continue to work properly with the normal timings.
Posted: 07:36am 04 Sep 2020
  Quote  But since the release version (or possibly one of the last betas that I missed) of 5.05.05 this has reported the error "Invalid in a program" for the setting of "SD Timing" and "RAM".
All option changes that force a restart are not allowed in a program as it makes no sense and will confuse the majority. Some were missed previously but hopefully they are all now caught
Posted: 09:52am 04 Sep 2020
  matherp said  All option changes that force a restart are not allowed in a program as it makes no sense and will confuse the majority. Some were missed previously but hopefully they are all now caught
OK, but these options are still reset when the firmware is updated ?
Should EXECUTE workaround the limitation or is it just something I need to accept ? It's not a big deal, but as you have observed before I seem to work on my CMM2 in an atypical manner.
