Local Time 15:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pinouts on back 40-pin connector for Nunchuks 1 & 2
William Leue
Posted: 08:10pm 03 Sep 2020
I have been working on building an adaptor box for supporting additional Nunchuks using the I2C pins available at the rear 40-pin data connector on the CMM2.
Most of the connections are obvious but I do have a couple of concerns.
According to online sources, the Nintendo connector has 6 traces, one of which is not used:
Pin  Use
1    +3.3v VCC
2    Ground
3    Data
4    No connection
5    Feeds 3.3v back for detection
6    Clock
So, looking at the pinout table in the CMM2 documentation, it seems clear that the following connections make sense:
CMM2 Pin     Nunchuk #1    NunChuk#2   Use
1               1                     +3.3v VCC
3               3                     I2C 1 Data
5               6                     I2C 1 Clock
7               5??                   detect Nunchuk?
9               2                     Ground
17                          1         +3.3v VCC
25                          2         Ground
27                          3         I2C 2 Data
28                          6         I2C 2 Clock
29??                        5??       detect Nunchuk?
The only two pins I am uncertain about are the two pins used by the Nunchuk to feed back 3.3v power so that the box can detect when the Nunchuk is connected. Any I/O pin could be used for this, but which ones are actually used by the CMM2 firmware?
-Bill
William Leue
Posted: 08:12pm 03 Sep 2020
Well, I forgot to switch to a monospaced font for the table so it looks ugly. Let me try again:
1               1                     +3.3v VCC
3               3                     I2C 1 Data
5               6                     I2C 1 Clock
9               2                     Ground
17                          1         +3.3v VCC
25                          2         Ground
27                          3         I2C 2 Data
28                          6         I2C 2 Clock
-Bill
Posted: 09:35pm 03 Sep 2020
You should be able to forget about the "detect nunchuk" pin.
MMBasic doesn't use it.
You could tie it to the 3.3V pin just in case your nunchuk uses that pin for power.
vegipete
Posted: 11:15pm 03 Sep 2020
The nunchuk port on the front doesn't use the detect pin so if your device works there, you won't need it for ports 1 or 2. But as Jim says, if you are making a pcb, add 2 pads that you can jumper if needed.
William Leue
Posted: 12:03pm 04 Sep 2020
Hmm. If I try to use the nunchuk commands without a nunchuk plugged in, CMM2 tells me that no nunchuk is connected. So if it does not use the 'detect' pins, how does it know?
-Bill
Posted: 12:09pm 04 Sep 2020
  Quote  how does it know?
Looks for a valid I2C response
Quazee137
Posted: 08:00pm 04 Sep 2020
William Leue have a look here
back of CMM2
