Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 904
Posted: 01:25am 03 Sep 2020
Hello all, One of the many great aspects of the LCD screens on the MM170 etc is that one can stop the program (^C) and the screen is retained so you can then interactively test graphics via the console. Can one do this on the CMM2? As far as I can tell - NO, not easily.
In Peter's first graphics tutorial he shows how you can draw a line over the text on a screen. But I am talking about complex graphics that you would not do via the console.
One option is to SAVE IMAGE from within the program, then, from the console, LOAD the image and then test your graphics - this works but is a bit clumsy.
Are there any better ways? Or, can an image be held stationary like a PC Desktop?
Cheers,
Andrew
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11892
Posted: 06:59am 03 Sep 2020
create the image on a page other than zero. Then when back at the command prompt execute PAGE COPY to restore the image
