Local Time 04:49 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: finding ticks in play sound
datawiz
Posted: 06:26pm 01 Sep 2020
I've growing quite fond of the CMM2's play sound features, and while tinkering with trying to figure out how to best utilize it, I thought about using 'settick' to run at an interval (500 ms) and do basic audio stuff as a background task.
I wrote some code to do that and play an increasing tone based on a counter. I expected to hear a slow rising tone, and it does that but there's an audio ticking going on before the sound increases. I figured this may be a byproduct of running it in an interrupt, so i wrote the loop to play in the main code and I still get ticking.
Here's something you can test with:
dim testmode% = 1
dim sflag1% = 500
if testmode% = 1 then
settick 500,soundfx,1
end if
cls
do
color rgb(rnd()*255,rnd()*255,rnd()*255)
print chr$((rnd()*93)+33);
' play outside of interrupt, still get a tick?
if testmode% <> 1 then
play sound 1,B,S,sflag1%,25
sflag1% = sflag1%+1
if sflag1%>1000 then sflag1%=500
pause 400
end if
pause 100
loop
' play sound in an interrupt, hear a tick.
sub soundfx
sflag1% = sflag1%+1
end sub
set testmode% = 1 to play sound in an interrupt, or any other value to play it inside the loop. Both methods produce an audible tick.
Am I doing something wrong, or is this expected behavior for play sound? If so, ss there a way to reduce/remove the ticking?
Thanks,
Rich/dw
hitsware2
Posted: 09:31pm 01 Sep 2020
With either SINE or TRIANGLE there is an
audible 'click' at the onset of the sound .
This is not unusual with many synths .
It is due to a fast attack on the envelope
and no 0 crossing ( the sound turns on during
a non 0 value in the waveform )
Using SQUARE or SAWTOOTH will mask the click .
my site
datawiz
Posted: 10:17pm 01 Sep 2020
  hitsware2 said  With either SINE or TRIANGLE there is an
Thank you for that explanation, that makes sense. I haven't done much with sound programming in the past, so I wasn't sure if this was normal or otherwise. I'll play around with different waveform types as I experiment more with sound.
Thanks,
Rich/dw
capsikin
Posted: 10:35pm 01 Sep 2020
  datawiz said  I've growing quite fond of the CMM2's play sound features, and while tinkering with trying to figure out how to best utilize it, I thought about using 'settick' to run at an interval (500 ms) and do basic audio stuff as a background task.
dim testmode% = 1
dim sflag1% = 500
end if
cls
do
sflag1% = sflag1%+1
pause 400
end if
pause 100
loop
sub soundfx
sflag1% = sflag1%+1
end sub
Thanks,
Rich/dw
When I was trying to make a rising or falling square wave sound and wanted it to sound clean, I found I needed to have the frequency and number of seconds it was playing for multiply to a whole number.
In your case it's playing for half a second at a time so the frequency needs to be an even number (multiple of 2)
I tried it with your code and it fixed the tick, so it does work with sine waves too. I replaced
sflag1% = sflag1%+1
with
sflag1% = sflag1%+2
For my chirps program I included a function to round the frequency, I haven't tried it in other programs.
function fixcycles(freq,t)
 'new value for freq that gives a whole number of cycles in time t.
 'integer number of cycles
 cycles% = freq * t / 1000
 if cycles% < 1 then cycles%=1
 fixcycles=cycles% * 1000 / t
end function
You give it a frequency and a number of milliseconds you want to play it for, it gives you a different frequency to play instead.
capsikin
Posted: 10:39pm 01 Sep 2020
This suggests if you can fix the click when you change sounds, you could fix the click at the starting and stopping of sounds by raising and lowering the volume over time instead of starting at full volume and stopping instantly from full volume.
capsikin
Posted: 10:48pm 01 Sep 2020
dim testmode% = 1
dim sflag1% = 500
end if
cls
do
sflag1% = sflag1%+1
pause 400
end if
pause 100
loop
sub soundfx
sflag1% = sflag1%+1
end sub
Thanks,
Rich/dw
sflag1% = sflag1%+1
with
sflag1% = sflag1%+2
end function
edited to add: another option would be to change how long you play the sounds for.
hitsware2
Posted: 10:55pm 01 Sep 2020
I need to digest that .....
my site
hitsware2
Posted: 10:57pm 01 Sep 2020
BBCBasic ENVELOPE
my site
capsikin
Posted: 12:03am 02 Sep 2020
  hitsware2 said  > frequency and number of seconds it was playing
I didn't explain that well, I've got two explanations that may make more sense.
First explanation:
The sound needs to play for a whole number of waves, not get cut off when it's played an extra half a wave, for example (I'm not sure I'm using the term "wave" correctly though. I could say "cycles" instead).
Second explanation, just uses examples.
If the sound plays for 1/2 of a second at a time, the frequency needs to be a multiple of 2.
If the sound plays for 1/10 of a second at a time, the frequency needs to be a multiple of 10.
If the sound pays for 1/50 of a second at a time, the frequency needs to be a multiple of 50.
hitsware2
Posted: 12:48am 02 Sep 2020
First explanation:
That makes sense for turning off ....
But not for turning on ...
You may be on to something though
I had some frequency dependent artifacts
happen ... I'll go back
my site
capsikin
Posted: 01:36am 02 Sep 2020
First explanation:
It might work for turning the sound on or off, but it was initially used for replacing the sound with a new sound, when I'm changing the frequency.
Which means I need to change the first explanation:
The sound needs to play for a whole number of cycles, so it ends at the same part of the cycle that it starts (and the same part that the next one starts at)
Edited 2020-09-02 11:42 by capsikin
