Local Time 15:52 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 OPTION RTC DRIVE LOW. Losing Time.
Chopperp
Posted: 07:20am 30 Aug 2020
I've noticed my CMM2 losing quite a bit of time lately when sitting at idle.
TIME$ gets updated from a GPS timestamp when my test program is up & running so not a problem until I stop for a bit. It relies on a reasonably accurate time to start properly. It was OK a week or so ago.
I did an OPTION LIST & found OPTION RTC DRIVE LOW which I can't get rid of or change. I wanted to change it to see what happens to the timing.
OPTION RTC CALIBRATE didn't improve matters much (running matherp's time test from a while ago)
Can't find any reference to it in the Manual.
Brian.
ChopperP
Posted: 07:24am 30 Aug 2020
Your options have somehow got corrupted. Use OPTION RESET and then redo your normal settings
Chopperp
Posted: 07:33am 30 Aug 2020
Thanks Peter
It was losing 3 seconds every 4 minutes.
Now much much better
Now to do the calibrate again
Brian
ChopperP
