Local Time 05:02 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Sprite movement with KEYDOWN(n)
shaputer
Posted: 04:17pm 29 Aug 2020
Hi Everyone,
For the life of me I can't figure out why my Sprite will only move once.  The sprite is a .png image.  A 64 X 64 small car.  Here is the code I am using.  Does anyone see any reason why my sprite only moves once when I press the arrow keys yet the value of the key pressed will print repeatedly.  I would like my sprite to move repeatedly.
Thanks !
CLS
LOAD BMP "SPLASH1.BMP"  'LOAD START SCREEN
SPRITE LOADPNG 1, "CarR.png"  'CAR FACING RIGHT SPRITE
SPRITE SHOW 1, 1, 16, 1  'SHOW THE CAR FACING RIGHT SPRITE
'random 'Sub Routine for Random Moves
DIM INTEGER I
X=0 'X COORDINATE
Y=0 'Y COORDINATE
DO
 IF KEYDOWN(0) THEN 'AT LEAST 1 KEY PRESSED
   IF TIMER > 200 THEN  'OPTIONAL-CHANGE TO ALTER RESPONSE TO KEY PRESSES
    TIMER = 0
    FOR I = 1 TO KEYDOWN(0) ' CHECK FOR ARROW KEYS AND ESC KEY
      PRINT KEYDOWN(I)
      PRINT
      IF KEYDOWN(I) = 27 THEN EXIT DO  'ESCAPE KEY TO EXIT
      IF KEYDOWN(I) = 130 THEN LEFT
      IF KEYDOWN(I) = 131 THEN RIGHT
      IF KEYDOWN(I) = 128 THEN UP
      IF KEYDOWN(I) = 129 THEN DOWN
    NEXT I
  END IF
 END IF
LOOP
CLS
PRINT "THANKS FOR PLAYING !"
END
SUB LEFT
 SPRITE NEXT 1, X + (-56), Y
 SPRITE MOVE 1
 PAUSE 100
END SUB
SUB RIGHT
 SPRITE NEXT 1, X + 56, Y
 SPRITE MOVE 1
 PAUSE 100
END SUB
SUB UP
 SPRITE NEXT 1, X, Y + (-36)
 SPRITE MOVE 1
 PAUSE 100
END SUB
SUB DOWN
 SPRITE NEXT 1, X, Y + 36
 SPRITE MOVE 1
 PAUSE 100
END SUB
SUB random
DO
 SPRITE NEXT 1, RND * 750, RND * 550
 SPRITE MOVE 1  'MOVE CAR RANDOMLY ON THE SCREEN
 PAUSE 500
LOOP
END SUB
If what you are doing is bringing out the worst in you than stop doing it.
Posted: 04:32pm 29 Aug 2020
Because you are not changing X or Y. Moves are absolute not relative
BTW there is no reason to use NEXT and MOVE except in particular circumstances where many sprites are moving - just use SHOW
Edited 2020-08-30 02:37 by matherp
shaputer
Posted: 11:24pm 29 Aug 2020
Thanks, Matherp !
That helped.  Got it moving now, but why is the MM.HPOS readonly variable not working like the MM.HRES ?  Is that variable no longer supported ?
Posted: 11:36pm 29 Aug 2020
  shaputer said  Thanks, Matherp !
MM.INFO(HPOS)
MM.INFO(VPOS)
shaputer
Posted: 04:13pm 30 Aug 2020
Thanks a lot !  Success !!!  Now to figure out Sprite Interupt
You hold down the right arrow key to make the car go.
I thought I would share so maybe it will help someone else.
DIM INTEGER I
START:
DO
    TIMER = 0
      'PRINT KEYDOWN(I) 'PRINT KEY THAT IS PRESSED
      'PRINT
    NEXT I
  END IF
 END IF
LOOP
CLS
END
SUB RIGHT
 FOR XR = XR TO MM.HRES STEP 26
  IF KEYDOWN(1) = 131 THEN
    SPRITE SHOW 1, XR, 1, 1
    'PRINT XR
    'PRINT
    PAUSE 200
  ELSE
    GOTO START
  END IF
 NEXT XR
END SUB
