Local Time 15:52 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: serial file transfer (to/from Raspberry Pi)
Posted: 11:30am 26 Aug 2020
Hi folks,
Apologies if this has been covered elsewhere, if so I'd appreciate a pointer to the appropriate thread(s).
I'm getting heartily sick of popping the SD card in/out of the CMM2 to transfer files to my Pi, or upload them to GitHub, and minicom and XMODEM are not a convenient combination for multiple file transfers.
What I wantis an ftp-like client from the Pi to the CMM2 with commands for navigating the CMM2 filesystem and getting/putting multiple files (with XMODEM perhaps being the underlying protocol).
I'm guessing this is a job for serial comms using COM1 or COM2 as described in the CMM2 manual, probably with a Pi client hewn from Python. I'm thinking I would rather not work over the serial console so that I'm not having to deal with any standard output/diagnostics the BASIC server program is generating.
I don't really have a clue on the hardware side, though I'm guessing this USB-TTL doodad (ostensibly one of these https://www.ebay.co.uk/itm/262285972686) that I've picked up on my travels might be part of the solution - the IC is unmarked, so don't ask me what it says
Does anyone have any advice / suggestions ?
1. Ideally the solution already exists, I don't want to re-invent the wheel.
2. Don't tell me about MMEdit , I'm sure it is wonderful, but using Windows is not convenient and Wine is not an option since the Pi is not x86.
Edited 2020-08-26 21:44 by thwill
Nimue
Posted: 12:04pm 26 Aug 2020
Have my eye on one of these for exactly your case - a WIFI enabled SD card.
Plug it into the CMM2 and access the storage via WiFi from another device...
https://www.amazon.co.uk/GuDoQi-Wireless-Memory-Digital-Camera/dp/B07436HRSY/ref=asc_df_B07436HRSY/?tag=bingshoppinga-21&linkCode=df0&hvadid=&hvpos=&hvnetw=o&hvrand=&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargid=pla-4584207586542308&psc=1
Nim
Posted: 12:08pm 26 Aug 2020
  Nimue said  Have my eye on one of these for exactly your case - a WIFI enabled SD card...
Hi "Nimue",
I seem to recall a relatively recent thread along the lines that these (especially the cheap-ish ones like this) have limited functionality and don't actually fulfill their promises.
Is anybody actually using one ?
Edited 2020-08-26 22:08 by thwill
Nimue
Posted: 12:13pm 26 Aug 2020
Sorry - I joined after those posts.
My bad.
N
Posted: 12:26pm 26 Aug 2020
  Nimue said  Sorry - I joined after those posts.
My bad.
N
It's only "your bad" if I turn out to be correct in my assertion
Edited 2020-08-26 22:32 by thwill
datawiz
Posted: 01:31pm 26 Aug 2020
I recently posted about a wifi library I created using an inexpensive esp8266 based microchip.
All the details are in this thread: wifi on the cmm2 thread
I've included several example programs, including cmm2 basic programs and python scripts to run on the remote device (Mac/Windows/Linux). One set of programs allows you to initiate an upload from the remote side to the cmm2 (cmm2 is the server) and another set allows you to initiate a download to the cmm2 (remote host is the server).
The protocol is very simple (as you'll see), but I've tested 100+ megabyte files across it and compared it to the original without any errors. It's not very practical with larger files, because serial speed is still limited to 115k and the effective transfer rate is a little more than half that, but for smaller files its very convenient and I've integrated it into my development workflow.
All the basics should be in the library to create something like you described. If you need any help, feel free to reach out.
Rich/dw
Edited 2020-08-27 00:31 by datawiz
Posted: 01:35pm 26 Aug 2020
Hi thwill,
Too bad you're on a Pi. If you where running W10, you could use MMEdit, and develop the code on the PC.
Maybe we should investigate a linux version of MMEdit compiled for the Pi. There is an X86 linux version of MMEdit.
http://www.users.on.net/~tassyjim/MMedit2.htm
Edited 2020-08-26 23:46 by Volhout
Posted: 06:21pm 26 Aug 2020
  datawiz said  I recently posted about a wifi library ...
Thanks Rich, I did notice it and then promptly forgot. It does sounds ideal so I've ordered the necessary bits of hardware to try it for myself.
This doesn't mean I'm not also interested in a hardwired serial solution, if only for educational purposes.
Posted: 06:24pm 26 Aug 2020
  Volhout said  Hi thwill,
Didn't I explicitly say "Don't tell me about MMEdit" ... I swear you are all on Jim's payroll
Posted: 06:48pm 26 Aug 2020
You got me. !!!
I have no solution, but I can imagine that you can create a geany profile to match MMBasic (keyword file). And a script to send your source via xmodem (minicom or similar) to the CMM is something that should also be possible.
If so you could use geany at the Pi.
I seem to remember from an earlier thread that someone created a geany profile. Not sure about the minicom script. Maybe I am mistaken...
I do not have a CMM2, but can try to work on something for the standard micromite (MX170).
Edited 2020-08-27 04:49 by Volhout
Posted: 07:34pm 26 Aug 2020
Hi Volhout,
I think you are trying to solve a problem I don't have.
I'm not looking for file transfer integrated with an editor, most of the time I'm happy with using "edit" on the CMM2 (via the serial console). What I want is console driven file transfer between CMM2 and Pi which is a little bit "richer" than raw XMODEM.
Thanks for turning me onto Geany though, VSCode (my current go to editor) on my Pi 3B+ runs like a one legged dog, perhaps Geany will be better.
Posted: 09:46pm 26 Aug 2020
That link is to a very old backup website that should not be used.
It is on an old ISP I no longer use and am unable to update or delete it.
CircuitGizmos
Posted: 10:16pm 26 Aug 2020
I think it would be great to have a variation on MMuploder that would let you drag and drop files to copy things serially to the SD card of the CMM2. Any named files dropped are xmodemed to the SD card with the same file name. No specific program running on the CMM - it just has to be in immediate mode. (option to ctrl-c beforehand)
This is a doable concept, right?
Posted: 10:35pm 26 Aug 2020
  CircuitGizmos said  I think it would be great to have a variation on MMuploder that would let you drag and drop files to copy things serially to the SD card of the CMM2. Any named files dropped are xmodemed to the SD card with the same file name. No specific program running on the CMM - it just has to be in immediate mode. (option to ctrl-c beforehand)
doable but not for the RPI (by me).
It would still be a gazillion times faster to swap the SDcard.
Can't the RPi use USB card readers?
CircuitGizmos
Posted: 10:49pm 26 Aug 2020
Sorry I hijacked the rPi discussion. I was thinking of this as a PC app. Just a way to drop .bas (and other light files) to the CMM2 over serial.
Posted: 06:31am 27 Aug 2020
  TassyJim said  Can't the RPi use USB card readers?
That does not appear to match what Tom wants. (Right?)
Edited 2020-08-27 16:31 by JohnS
Posted: 09:43am 27 Aug 2020
That's correct, my Pi already has a card reader hanging off it by an extension cable.
I'm railing against the nuisance of popping the SD card, plugging it into the reader, navigating to the folder/drive, doing "stuff", removing all connections to the folder/drive so it can be ejected safely, ejecting in the O/S, physically popping the SD card, plugging it into the CMM2.
That's fine once per session to upload progress to GitHub, but if I just want to move a couple of files back and forth from the Pi so I can use its richer toolset, or transfer something downloaded from the internet then it gets annoying.
"datawiz"s work sounds like a great starting point from which to start investigating something better.
Carnifex
Posted: 02:29am 28 Aug 2020
Linux has a couple of tools that might serve your purpose.
Minicom has its own built in xmodem protocol, which will let you navigate the local file system and choose what file you want to send to the CMM2, but it will not let you look at the the CMM2's file system. You can also use screen and sx, but that lacks the ability to look at either file system. I think Minicom is your best bet.
Posted: 08:58am 28 Aug 2020
Hi Carnifex,
From the first message in the thread:
  "thwill" said  ... and minicom and XMODEM are not a convenient combination for multiple file transfers.
Or to put it another way I find minicom to be a dreadful piece of software, but YMMV
I'm looking forward to building my own software on top of "datawiz's" work with the  esp8266.
