Local Time 16:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "Amazin" program for CMM2
William Leue
Posted: 07:57pm 25 Aug 2020
Here is a program that generates a random maze on the screen using a depth-first algorithm. It then runs the maze using a similar depth-first maze running algorithm and shows its path as the search runs; and finally, using the history of dead ends that it finds while running the maze, removes most of the dead ends from the displayed run, leaving a much shorter path from beginning to end.
-Bill
Amazin.zip
RonnS
Posted: 08:34pm 25 Aug 2020
Nice,
works on ARM Mite F4 too by change line 44 and 45
