Local Time 16:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sprite feature suggestion/request
capsikin
Posted: 10:26am 22 Aug 2020
Sprites would be easier and faster to use if you didn't have to make a loop to erase and redraw them in order to make changes behind them. MMBasic already provides the ability to do the erasing and redrawing itself for SPRITE SCROLL and SPRITE MOVE, but we don't have full access to this feature. So we can't use it to print behind sprites, or copy a background page behind sprites, or display something new when the screen is scrolled behind sprites.
I can think of two ways to improve this.
1 - specifically have a command like page copy, but it copies graphics behind sprites. It could be a sub command of SPRITE, BLIT, or PAGE.
2 - have a SPRITE command to temporarily hide the sprites, and they get redrawn when you do SPRITE MOVE, or some other chosen command (SPRITE RESTORE?)
Command name ideas I had: SPRITE MOVE OFF. SPRITE MOVE HIDE. SPRITE SHOW OFF. Or maybe something starting with SPRITE HIDE.
The second way is more flexible, because in the time between hiding and restoring the sprites, you could use any graphics commands you want to modify the background page. PRINT, CIRCLE, PAGE COPY, BLIT.
So you could do something like this:
SPRITE HIDE
PRINT "Hello from behind the sprites"
SPRITE RESTORE
The temporarily hidden sprites would be in a pending state until they are restored.
Posted: 10:44am 22 Aug 2020
Nice idea
Try the attached:
SPRITE HIDE ALL will remove all sprites
SPRITE RESTORE will replace them
I hope
CMM2V1.5 (2).zip
Note if this works I need to do some more work to trap SPRITE command that mustn't be used when HIDE ALL is active
Edited 2020-08-22 20:59 by matherp
capsikin
Posted: 11:35am 22 Aug 2020
  matherp said  Nice idea
Try the attached:
I hope
CMM2V1.5 (2).zip
That was quick! USB keyboard's not fully working - it works in the editor but not on the command line, so I need to use the terminal connection.
The new commands work though.
Posted: 11:56am 22 Aug 2020
  Quote  USB keyboard's not fully working - it works in the editor but not on the command line
Oops - sorry
CMM2V5.05.05b18exp.zip
capsikin
Posted: 12:45pm 22 Aug 2020
Thanks.
I have another suggestion/request. I don't know of an easy way to hide a sprite during a SPRITE MOVE. It could be either SPRITE NEXT spr,x,y, if you allow the coordinates to move it completely offscreen, or a new subcommand like SPRITE NEXT HIDE.
Or an alternative would be enabling switching off individual sprites during a SPRITE HIDE ALL, so they don't come back on at the end.
Oops - sorry
That works, thanks. I made a demo with the new commands (flickering a bit because I haven't used double buffering).
MODE 1,8
CLS
RBOX 10,10,20,20,3,RGB(WHITE),RGB(MAGENTA)
SPRITE READ 1,10,10,20,20,0
SPRITE READ 2,10,10,20,20,0
SPRITE READ 3,10,10,20,20,0
bg=RGB(CYAN)
CLS bg
y=200
SPRITE SHOW 1,10,y,0,0
SPRITE SHOW 3,10,y,0,0
x=11
do
 x=(x+3) mod 600
 pause 50
 SPRITE NEXT 1,x,y
 SPRITE NEXT 3,x,y+x/2
 SPRITE MOVE
 SPRITE SHOW 2,700-x,y+50,0
 r=RND*255
 g=RND*255
 b=RND*255
 SPRITE HIDE ALL
 CIRCLE RND*800, RND*600, RND*100,,,0, RGB(r,g,b)
 PAGE SCROLL 0,1,1
 SPRITE RESTORE
loop
Edited 2020-08-22 22:45 by capsikin
Posted: 12:55pm 22 Aug 2020
  Quote  I have another suggestion/request. I don't know of an easy way to hide a sprite during a SPRITE MOVE. It could be either SPRITE NEXT spr,x,y, if you allow the coordinates to move it completely offscreen, or a new subcommand like SPRITE NEXT HIDE.
If I've got it right you can use SPRITE NEXT either before or during the HIDE and the RESTORE will put the sprites in the new position and trigger the collision detection
capsikin
Posted: 01:13pm 22 Aug 2020
I don't think that's it. What I mean is, I've got a sprite displaying and want to remove it. I don't want to just SPRITE HIDE 1 in case there's another sprite in front of it. SPRITE NEXT can only put it somewhere else on the screen, not right off screen.
Good to know I can use SPRITE NEXT before/during a SPRITE HIDE ALL though.
If you plan to allow SPRITE HIDE 1 during a SPRITE HIDE ALL that might do what I want.
JoOngle
Posted: 01:46pm 22 Aug 2020
IMHO sprites should be non-destructive aka not interfere with the background (or any foreground) graphics at all.
Hide and restore is a needed function, but to use it to allow other changes to happen to the screen is sorta cheating and will make games horribly slow when this could all be done in the OS itself. (not a critique, thanks for your amazing work Peter), it's just an observation (not to mention, perhaps wishful thinking here), but then again I come from a background where sprites where real sprites, aka totally independent of the background graphics, like miniature screens if you like. Even the arcade machines had these sprites often referred to as "player / missile" objects.
Posted: 01:51pm 22 Aug 2020
OK Try this.
SPRITE HIDE SAFE n
This will remove a sprite irrespective of if other sprites are on top of it.
It is of course much less efficient than using a simple hide if you know the sprite isn't covered
CMM2V1.5.zip
box 0,0,50,50,4,rgb(red),rgb(white)
sprite read 1,0,0,50,50
sprite copy 1,2,2
sprite show 1, 150,150,1
sprite show 2, 170,170,1
sprite show 3, 190,190,1
pause 2000
sprite hide safe 2
pause 2000
sprite hide safe 1
pause 2000
pause 2000
sprite hide safe 3
do
loop
capsikin
Posted: 01:59pm 22 Aug 2020
  matherp said  OK Try this.
SPRITE HIDE SAFE n
CMM2V1.5.zip
sprite copy 1,2,2
pause 2000
sprite hide safe 2
pause 2000
sprite hide safe 1
pause 2000
pause 2000
sprite hide safe 3
do
loop
Thanks, I'll test that tomorrow.
Posted: 02:10pm 22 Aug 2020
Even better
SPRITE SHOW SAFE n, x, y, layer
CMM2V1.5.zip
box 0,50,50,50,4,rgb(green),rgb(yellow)
sprite read 2,0,50,50,50
pause 2000
sprite show safe 1,180,180,1
pause 2000
sprite show safe 2,190,190,1
pause 2000
sprite show safe 1,200,200,1
pause 2000
sprite hide safe 3
do
loop
capsikin
Posted: 04:30am 23 Aug 2020
This is good, it's something I hadn't thought of initially - not having to have separate erase/redraw loops for moving the sprites with SPRITE NEXT and for changing the background with SPRITE HIDE ALL / SPRITE RESTORE
  matherp said  Even better
CMM2V1.5.zip
Thanks! I tried both the test programs you gave, using this later firmware. They worked correctly. I removed the "SAFE" and tried again, and got screen corruption as expected.
Standalone commands like this will be easy for people to use, which is good. I was initially thinking of something I could bundle with other commands though, and only need one erase/redraw for all of them when I do SPRITE MOVE or SPRITE HIDE ALL, for efficiency.
I have thought of ways I can work around it though, by limiting how many SPRITE HIDE SAFE commands I try to do at once, and/or by moving the sprites into the corner so they only have one pixel on screen, and make it a transparent pixel.
  JoOngle said  IMHO sprites should be non-destructive aka not interfere with the background (or any foreground) graphics at all.
I've replied to this on the other thread.
Edited 2020-08-23 14:32 by capsikin
