Local Time 14:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Positioning and locating cursor
Herry
Posted: 09:22pm 20 Aug 2020
In the old Microsoft QBASIC there were commands that allowed the cursor to be programmably be positioned anywhere on the screen or its position (as influenced by up and down arrows) to be reported back to the program, using LOCATE and POS, neither of which seem to be in Maximite Basic. Any suggestions?
Senior?!  Whatever it says, I'm a complete and utter beginner...
Herry
Posted: 09:40pm 20 Aug 2020
Now found POS in obsolete list but it is apparently for horizontal cursor position on a line. I want to be able to locate the vertical position on the screen...
The cursor will be positioned immediately after and text that you show with PRINT.
IT will only show if the system is waiting for input.
To print text at a predetermined location you can use PRINT @(x,y)
If you follow the text to print with a semi-colon, the cursor will not move to a new line.
You can also use the TEXT command.
To monitor the arrow keys, use either INKEY$ or KEYDOWN, depending on your needs (or preference).
Posted: 09:45pm 20 Aug 2020
if it's on the serial console using a VT terminal emulator (I use PuTTY)
then this will help a lot
http://www.fruitoftheshed.com/MMBasic.Simple-screen-Control-for-ANSI-based-Consoles-VT100-etc.ashx  also links (at the bottom) to a nice on-screen string editor; pass a string in , maximum length, and get it back. Non-blocking, and won't muck up your nice terminal screens like Input
Herry
Posted: 09:50pm 20 Aug 2020
  TassyJim said  The cursor will be positioned immediately after and text that you show with PRINT.
Thanks. Found PRINT@, now to look into INKEYS and KEYDOWN
UPDATE*** Cannot see how I can report the x or Y position of the cursor using either INKEY$ or KEYDOWN. BTW the old BASIC used CSRLIN
Edited 2020-08-21 07:58 by Herry
Chopperp
Posted: 11:00pm 20 Aug 2020
@Herry
Don't worry about it. A few more posts & you will become a GURU!!!
Brian
ChopperP
Herry
Posted: 11:41pm 20 Aug 2020
I think I've got it. I'll establish a datum by printing @(x,y). Then I'll keep track of cursor movements up or down (in a variable),  and that way I've got the cursor posn.
capsikin
Posted: 01:03am 21 Aug 2020
I wrote a locate function for backwards compatibility with older basic listed here.
  Herry said  I think I've got it. I'll establish a datum by printing @(x,y). Then I'll keep track of cursor movements up or down (in a variable),  and that way I've got the cursor posn.
And I think you'd need to update the cursor position with print @(x,y); when it moves, I don't think the keypresses will move it themselves.
Herry
Posted: 01:12am 21 Aug 2020
  capsikin said  I wrote a locate function for backwards compatibility with older basic listed here.
Yes, working on that
Herry
Posted: 02:20am 21 Aug 2020
Making good progress, but it would be good if there could be an x,y option in text lines and characters...
KeepIS
Posted: 04:39am 21 Aug 2020
MM. HRES
Returns the width of the display (the X axis) in pixels.
MM. VRES
Returns the height of the display (the Y axis) in pixels.
MM.INFO(FONTHEIGHT)
Returns the height of the current font (in pixels).  All characters in a font have the same height.
MM.INFO(FONTWIDTH)
Returns the width of a character in the current font (in pixels).  All characters in a font have the same
width.
MM.INFO(HPOS)
Returns the X coordinate of the text cursor (ie, the horizontal location (in pixels) of where the next
character will be printed on the VGA monitor)
MM.INFO(VPOS)
Returns the Y coordinate of the text cursor (ie, the vertical location (in pixels) of where the next
I use these to calculate and return the cursor position in a small edit window function.
capsikin
Posted: 12:44am 29 Aug 2020
  Herry said  Making good progress, but it would be good if there could be an x,y option in text lines and characters...
That gives me an idea.
  KeepIS said
MM.INFO(FONTHEIGHT)
MM.INFO(FONTWIDTH)
width.
I'm going to try something like this next time I need it:
Sub LOCATECELL x,y
 Print @(x*MM.INFO(FONTWIDTH),y*MM.INFO(FONTHEIGHT));
End Sub
xmarkf
Posted: 11:01am 27 Sep 2020
This is probably worth a new discussion but on the topic of VTs /consoles.
I am wanting to use the CMM2 as a terminal. I noticed when you have serial terminal connected it does the VT100/52 thing. Can this be forced on when a program is active to become a VT100?
I would love to use it as what I call a K.A.T. Kick Ass Terminal. With graphics etc. for my Zeta2 I so want a 3D rotating Enterprise on the opening screen of super star trek.
