Local Time 05:31 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Towers of Hanoi Puzzle
William Leue
Posted: 04:56pm 20 Aug 2020
Attached is a ZIP file for the Towers of Hanoi puzzle, a CMM2 MMBasic program I recently completed.
The Towers of Hanoi puzzle consists of three towers the first of which holds a number of disks of steadily decreasing size, just like a kid's stacker toy.
The object of the puzzle is to move the disks from the first (left-hand) tower to the center tower. But, there are two restrictions:
 a) You can only move one disk at a time
 b) At all stages of the solution, you can NEVER have a larger disk on top
      of a smaller disk.
Persons familiar with the puzzle know that for N disks, the solution that uses the fewest number of moves is 2 raised to the Nth power, minus one.
This program lets you select the number of disks from 3 to 12, choose an automatic solution which can be single-stepped, or a manual solution where you move the disks yourself. The program will tell you when you succeeded and if you used only the minimum number of moves.
Enjoy!
-Bill
Hanoi.zip
