Local Time 05:30 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Extend file read/write functions to work with terminal in/out ?
Posted: 12:51pm 20 Aug 2020
Would it be a good idea / possible to have LINE INPUT #nbr, PRINT #nbr and all their friends work with #nbr = 0 meaning read / write from the terminal ? i.e. the same as vanilla LINE INPUT and PRINT.
This would be convenient and avoid an IF statement or two when writing programs where reading/writing both to files or the terminal are valid.
Posted: 01:01pm 20 Aug 2020
Have you tried it?
Posted: 01:08pm 20 Aug 2020
  matherp said  Have you tried it?
Obviously not or I would have found out it already works
Proof, if it were needed, that I spend too much time on the forum and not enough time on the CMM2 ... or my day job for that matter.
Cheers,
