Local Time 05:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Bug reporting
Posted: 04:44pm 19 Aug 2020
Polite request: please do not report bugs in any version before the release version 5.05.04. If you have an issue with an earlier version please upgrade to 5.05.04 and recheck if the problem still exists. Before reporting an issue with 5.05.04 please check
https://geoffg.net/Downloads/Maximite/CMM2_Current_Bug_List.txt
to see if I am already aware of the problem
Edited 2020-08-20 02:45 by matherp
twofingers
Posted: 05:21pm 19 Aug 2020
Hi Peter,
I found a possible bug (or a feature?).
When I try to insert (F7 in the editor) a file without an (file name) extension, an error message appears.
"test.bas" (works)
"test" (works not)
Michael
EDIT:
CMM2 Ver. 5.05.04
Edited 2020-08-20 03:27 by twofingers
The lone and ...
Posted: 05:30pm 19 Aug 2020
F7 assumes a .bas file if no extension is specified. This is consistent with EDIT but may not always be what you want. No right answer on this one but that is why you see the issue.
twofingers
Posted: 05:58pm 19 Aug 2020
Hi Peter,
  Quote  F7 assumes a .bas file if no extension is specified.
I can confirm that. But does this mean that it is desired that files cannot be loaded without extension?
... I found a work around: a dot instead of the extension.
"test." (works for files without extension)
Sorry for the alarm!
The lone and ...
