Local Time 05:44 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: microcomputer-style game sounds
capsikin
Posted: 10:46pm 14 Aug 2020
Here's a simple program that demos some possible game sounds. They remind me a bit of BBC micro or ZX spectrum game sounds.
'change this to skip some
goto 100
100
for h=1 to 2
 chirp 1,5,1200,50,20
next
pause 300
200
for h=1 to 2
 chirp 1,5,600,50,20
next
300
for h=1 to 12
 pause 500
 freq=2800-200*h
 print "single chirp, start frequency ";freq
 chirp 1,5,freq,50,20
next h
play sound 1,B,O,300
pause 1000
400
print "chirps with different t"
for h=1 to 4
 pause 500
 freq=600
 print "single chirp,t=";20*h
 chirp 1,5,freq,50,20*h
next h
pause 1000
500
print "chirps with different d"
for h=1 to 4
 pause 500
 freq=2000
 print "single chirp, d=";50*h
 chirp 1,5,freq,50*h,20
next h
600
 for h=1 to 5
 'pause 500
 freq=1600-200*h
 print "upward chirp, start frequency ";freq
 chirp 1,5,freq,-50,20
next h
pause 1000
700
for h=1 to 5
 pause 500
 freq=1600-200*h
next h
pause 1000
800
for h=1 to 5
 pause 500
 freq=1600-200*h
 print "upward chirps repeated, start frequency ";freq
 for h2=1 to 5
 next
next h
pause 1000
end
sub chirp sets,reps,f,d,t
for k=1 to sets
 ' if f and d are multiples of 50 (50 cycles per second)
 ' and t is 20 (20ms), a 50th of a second, sound will be smoooth
 ' more generally if f and d are multiples of 1000/t.
 for n=f to f-d*reps step -d
   play sound 1,B,q,n
   pause t
 next n
next
end sub
In a real game it's probably better to use interrupts instead of pause, so the game doesn't have to wait while the sound is playing. But that's more work than I wanted to put into this, at least for now.
capsikin
Posted: 05:35am 15 Aug 2020
Here are some in the ZX Spectrum style where it would make tiny little bits of sound and then have a pause in the sound for a fraction of a second while it did other things.
'play a square wave
sub sq freq, dur
 play sound 1,B,Q,freq
 pause dur
 play stop
end sub
for n=1 to 10
 sq 1000-50*n,3
 pause 100
next
f=1000
for n=1 to 20
 sq f,3
 pause 70
 f=INT(f*1.1)
next
Edited 2020-08-15 15:36 by capsikin
capsikin
Posted: 01:20am 20 Aug 2020
Here's a program to make chirp/zap noises, and let you modify the sounds with the arrow keys.
chirps-ui3.bas.zip
update: I made another version of my interactive chirp program, to give it a blue background, and use 320x200 resolution so the text is bigger. Not sure I like the visual style but I didn't like the previous one that much so I wanted to try something different. Also I made the quit key work.
chirps-ui4.bas.zip
update 2: I've put it on gitlab and made another version. This one has colour, and looks a bit neater.
Link to latest version, as a zip download: https://gitlab.com/caspianmaclean/chirps-ui-cmm2/-/archive/master/chirps-ui-cmm2-master.zip
Gitlab project page
Edited 2020-08-29 20:25 by capsikin
