Local Time 16:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Font size on CMM2 editor ....
hitsware2
Posted: 09:02pm 08 Aug 2020
When I use FONT to get a comfortable size ,
and then switch to EDIT , the font shrinks back .
Any way around that ... Or am I simply missing
something ?
my site
Atomizer_Zero
Posted: 09:31pm 08 Aug 2020
As far as I know, the font in the editor can't be changed. You can use a different font through serial on Tera Term (or similar terminal software for serial connection), which will give you the functionality of the editor, but on your PC, but with a different font and size.
Of course, you can set the Font in a program, and when run will change the font then, but of course, as soon as the program is exited, the font will change back.
Posted: 09:33pm 08 Aug 2020
What commands are you using to set the font?
From the manual
  Quote  OPTION EDIT FONT SMALL | NORMAL | MEDIUM | LARGE
Sets the font to be used in the editor and file manager. The default is NORMAL which is a 8x12 pixel font.
Atomizer_Zero
Posted: 09:43pm 08 Aug 2020
I have the 5.05.03 version of the manual, and that's option isn't in the list of options...
I really should print/order a new manual... lol
hitsware2
Posted: 09:59pm 08 Aug 2020
Yea....Found that : )
I was using FONT
Still goes back small with error messages , but that ' s OK
my site
