Local Time 06:19 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 and timing some simple code.
KeepIS
Posted: 03:50am 06 Aug 2020
CMM2 and timing some code.
I was interested in the speed hit between a few of the MMBasic commands.
As most likely know, unless the default console option is changed, Print and Print @ output to the USB console port and VGA console screen, however the Text command is more a graphic write to the Console VGA screen only.
I timed Text write for x number of strings to the Console screen and Print, with and without the USB console enabled.
Print @(x,y) USB Console disable: 776.672ms
Print @(x,y) default Console setting: 6000,615ms
Text x,y: 722.295ms  ***
Next: Simplistic code I used for testing: if then elseif compared to 3 separate if then, and a select case.
 x=0 : i=40000
 timer=0
 do
   x=x+1
   if x=i then
      j=j
   elseif x=i*2 then
      j=j
   elseif x=i*3 then
      exit do
   endif
 loop
 print timer
 x=0 : timer=0
 do
  x=x+1
  if x=i then
    j=j
  endif
  if x=i*2 then
    j=j
  endif
  if x=i*3 then
    exit do
  endif
 loop
 print timer
 x=0 : timer=0
 do
   x=x+1
   select case x
     case i
       j=j
     case i*2
       j=j
     case i*3
       exit do
   end select
 loop
 Print timer
if then elseif: 3383.67ms
3 x if then: 3473.181ms
Select Case: 2212.352ms  **** as expected
Next An if then test of two conditions compared to two separate single tests.
x=0 : j=1
 timer=0
   x=x+1
   if x=i and j then
     j=j
   elseif x=i*2 and j then
     j=j
   elseif x=i*3 and j then
     exit do
   endif
 loop
 print timer
 x=0
 timer=0
 do
   x=x+1
   if x=i then
     if j then
       j=j
     endif
   elseif x = i*2 then
     if j then
       j=j
     endif
   elseif x = i*3 then
     if j then
       exit do
     endif
   endif
 loop
 print timer
if x and j  : 4239.293
Separate if : 3389.422 ***
I purposely use an if-then-endif for the second condition as a number of lines of code could likely be used in that branch condition, not trying to streamline the tests just see which is faster with a large number of iterations.
NANO:Inverter V 8.4ksLinux AvrDude GUI script V4.1
Posted: 06:34am 06 Aug 2020
I'm confused!
Your timings - things like 3383.67ms - mean things took seconds?!
Do you mean us or what?
KeepIS
Posted: 06:38am 06 Aug 2020
The loop iteration is 120,000 times, so it's in Ms.
Edited 2020-08-07 18:48 by KeepIS
Posted: 05:59pm 10 Aug 2020
Your test is simplistic in one important respect. Console I/O is buffered and executes under interrupt control. As long as you don't fill the console output buffer which is 8192 bytes then the overhead of writing to the console is minimal. As soon as the buffer is full then the output rate is determined by the baudrate as the processor stalls waiting for space in the buffer.
KeepIS
Posted: 09:40pm 10 Aug 2020
Yes, the console test really should be kept to a lower write value, the console baud rate was 230400.
