Local Time 16:51 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Framebuffer commands
electrotrains
Posted: 09:37am 03 Aug 2020
I'm trying to work out if the FRAMEBUFFER commands will help me in my attempt to write a scrolling, tile-based game in MODE 3,16 (320x200 16-bit).
Is the framebuffer really just like a PAGE, and differs only in that it can be bigger than the selected MODE resolution?
PAGE 0 is still what is visible on screen?
So I could do something like:
MODE 3,16
FRAMEBUFFER CREATE 640,480
FRAMEBUFFER WRITE
DO
' drawing to a 640x400 framebuffer goes here
' now we copy a 320x200 'window' to page 0
FRAMEBUFFER WINDOW x,y,0,B
LOOP
and I could have a 640x400 map, with a scrolling 320x200 region visible on screen?
Is using a FRAMEBUFFER to do this faster than just PAGE SCROLLing an offscreen page,  BLIT new tiles into the gaps, then doing a PAGE COPY to 0 to finally display?
Robin
https://github.com/robinhedwards
Posted: 10:41am 03 Aug 2020
  Quote  Is the framebuffer really just like a PAGE, and differs only in that it can be bigger than the selected MODE resolution?
Yes and Yes
  Quote  Is using a FRAMEBUFFER to do this faster than just PAGE SCROLLing an offscreen page
Probably slightly but should be conceptually simpler
