Local Time 06:46 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CCM2 on/off switch?
MikeAlves
Posted: 02:49pm 01 Aug 2020
Hello guys,
I am planning to get one of these:
https://www.digikey.com/products/en?keywords=EG2364-ND
However, are there specific instructions on how to solder this type of switch?
Thanks,
Mike
Posted: 02:56pm 01 Aug 2020
Hi Mike,
Not really they are very straight forward..
Position the switch and tack solder the front legs whilst holding it flat and square on the pcb
If happy solder the back one of the curved legs and check alignment again.. if ok solder one of the front legs and another check then solder all the legs..
It is a very easy process and takes less than a minute..
MikeAlves
Posted: 09:13pm 01 Aug 2020
Thanks!
mkopack73
Posted: 01:59am 02 Aug 2020
It literally took me longer to desolder the small wire jumper out that was on my board forcing it to always be on than it did to install the switch...
