Local Time 16:58 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Copy/paste between files and moving files.
capsikin
Posted: 04:35am 30 Jul 2020
Hi, I don't think on the CMM2 you can copy from one file in the editor and paste into another. My workaround has been to take out the SD card and do it on another computer. Have people been using any other workarounds?
(update: possibly using F7 and F8 would help)
Moving files - the copy command in the file manager doesn't show you where the other directories are. I'd like to be able to see some of the directory structure when moving/copying a file into another location. My workaround has been using another computer again, but I'm guessing I could use basic commands including list files and copy.
Has anyone copied/moved things between directories on the CMM2?
Edited 2020-07-30 14:44 by capsikin
twofingers
Posted: 06:24am 30 Jul 2020
Hi capsikin
my workaround (quick and dirty):
' *******  Merge for CMM2, combines 2 files *******
'*****************  V 0.01  ***********************
Const TRUE  =1
Const FALSE =0
Dim F1$,F2$,TF$,YN$,FSize As integer
'Input "file1" F1$
'Input "file2" F2$
'Input "Target file" TF$
F1$="M.txt"
F2$="S.txt"
TF$="New.txt"
'Print FileExists(F1$)
'Print FileExists(F2$)
'Print FileExists(TF$)
Print "Merge for CMM2"
Print
Print "Files to merge: " F1$ " + " F2$
Print "Target file   : " TF$
If Not FileExists(F1$) Then Print F1$ " doesn't exist!":End
If Not FileExists(F2$) Then Print F2$ " doesn't exist!":End
If FileExists(TF$) Then
  Print "Target file: " TF$ " exist! Overwrite? ";
  Input "(Y/N)";YN$
  If YN$<>"Y" And YN$<>"y" Then
    Print :Print "Program terminated!"
    End
  EndIf
EndIf
FSize=Merge(F1$, F2$, TF$)
Print :Print TF$ " created, file size = " FSize
End
Function Merge(FN1$, FN2$, TFN$) As integer
   Open FN1$ For input As #1
   Open TFN$ For output As #3
   Do While Not Eof(#1)
     Print #3, Input$(1,#1);
     Merge=Merge+1
   Loop
   Close #1
   Open FN2$ For input As #2
   Do While Not Eof(#2)
     Print #3, Input$(1,#2);
     Merge=Merge+1
   Loop
   Close #2,#3
End Function
Function FileExists(FileName$) 'NEW untested
 FileExists=not(MM.INFO(FILESIZE file$)=-1)
End Function
'Function FileExists(FileName$)
'  On error skip
'  Open FileName$ For input As #10
' If MM.Errno=0 Then
'   FileExists=TRUE
'   Close #10
' Else
'   FileExists=FALSE
' EndIf
' On error abort
'End Function
Perhaps we should have something similar (but better) in the CMM2 Basic?
Michael
Posted: 06:39am 30 Jul 2020
Open the first file, Select the information required (F$, then F5) and press F8 to save as a file
Open the second file and press F7 to paste the saved selection
To copy files between directories just use the copy command at the prompt
Edited 2020-07-30 16:43 by matherp
Posted: 07:19am 30 Jul 2020
To copy from the command-line, I like to change to the destination directory and do the copy from there.
mkdir "test"
> cd "test"
> chdir "test"
> copy "a:/temp.bas" to "new.bas"
> files
17:15 30-07-2020       2129  new.bas
twofingers
Posted: 08:20am 30 Jul 2020
Correction:
End Function
should be:
  FileExists=not(MM.INFO(FILESIZE FileName$)=-1)
End Function
********** EDIT ********************
Uhhh ...
It seems that MMBasic is better than I thought! I found just out I CAN INSERT files with "F7"(while in the editor). It works exactly as I thought it should.
Perfect!
Edited 2020-07-31 03:53 by twofingers
