Local Time 07:14 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New CMM2 user here + possible colour bug.
JoOngle
Posted: 02:12am 26 Jul 2020
First of all, finally inside the forum.
Been lurking for a while before and after I got my first CMM2 (thanks to the Admin for helping me inside the forum now that there are some email notification issues).
When I saw it on 8-Bit guy, I was sold, right away. I'm an old school Basic/assembly coder from the Commodore 64 / Amiga era, I even worked as a service Tech for our local certified chapter of Commodore Computers as a warranty repairman, fun times!
I always loved the simplicity of the Commodore 64, just turn it on, and program straight  away, if you had an IDEA, you could execute it on the spot, the I/O ports too, which I used extensively.
Then I saw the Maximite 2, and was blown away by it. My little childhood dreams of creating simple 2D arcade games came back in me, and I had to have one.
Received mine from UK (micromite.org), assembled (Yes I could do it, but I am lazy, period).
I was super pleased to see how simple it was to code on, I could literally just skip the manual and code straight away on it, I started by changing existing demo code, such as the circles program which is very simple, and I wanted to check out the colour palette.
And here comes the problem...or my own fault? Don't know yet, but I'll ask the more experienced of you (that's basically anyone but me in here):
See something weird?
That's right - the blue is missing some shades, 4 of them I think, why is that (if you zoom in a little you can see the entire code right there, so yell out at me if you spot an error that could result in such a weird colourshades-skipping in the blue).
Again, thanks for your reply - and I am excited like a little kid when I read your posts in here every day.
Edited 2020-07-26 12:15 by JoOngle
mkopack73
Posted: 02:23am 26 Jul 2020
Ok, haven't tried your code... and the folks who have been at it more than me can maybe comment in BUT...
No I think it's proper...
(this is where reading the manual would help you    See page 27)
Depending upon which color mode you're in, the green channel gets 1 extra bit (and thus gets some additional shades...)
If you look, the Red follows the same pattern as the blue..
Try setting the mode as "1,8" (or 12 or 16) to set the different color bit depth)... I believe if you don't you're likely in 12 (or whichever color depth the last thing you ran is in, but I think the editor is in 8 bit).
See if that changes things at all...
Edited 2020-07-26 12:27 by mkopack73
Posted: 02:42am 26 Jul 2020
This will show you the full range of modes and the difference in colour when using them.
 ' test card for CMM2
 ' TassyJim May 2020
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 DIM INTEGER wd, ht, wbox, sh, x, w, n, nn, m
 DIM FLOAT a
 DIM k$, imgtitle$, fname$, mess$
 DIM INTEGER c(8)
 c(0) = RGB(BLACK)
 c(1) = RGB(YELLOW)
 c(2) = RGB(CYAN)
 c(3) = RGB(GREEN)
 c(4) = RGB(MAGENTA)
 c(5) = RGB(RED)
 c(6) = RGB(BLUE)
 c(7) = RGB(WHITE)
 c(8) = RGB(64,64,64)
 cls
 DO
   SELECT CASE m
     case 0
       MODE 1, 8
     CASE 1
       MODE 1, 8
       nn = 10
       a = 1 ' aspect ratio used in the CIRCLE command.
       imgtitle$ =" MODE 1,8 Ratio "+str$(a,1,2)+" "
     CASE 2
       MODE 1, 12
       nn = 10
       imgtitle$ =" MODE 1,12 Ratio "+str$(a,1,2)+" "
     CASE 3
       MODE 1, 16
       nn = 10
       imgtitle$ =" MODE 1,16 Ratio "+str$(a,1,2)+" "
     CASE 4
       MODE 2,8
       nn = 8
       a = 1.08 ' aspect ratio used in the CIRCLE command.
       imgtitle$ =" MODE 2,8 Ratio "+str$(a,1,2)+" "
     CASE 5
       MODE 2,12
       nn = 8
       imgtitle$ =" MODE 2,12 Ratio "+str$(a,1,2)+" "
     CASE 6
       MODE 2,16
       nn = 8
       imgtitle$ =" MODE 2,16 Ratio "+str$(a,1,2)+" "
     CASE 7
       MODE 3,8
       nn = 4
       imgtitle$ =" MODE 3,8 Ratio "+str$(a,1,2)+" "
     CASE 8
       MODE 3,12
       nn = 4
       imgtitle$ =" MODE 3,12 Ratio "+str$(a,1,2)+" "
     CASE 9
       MODE 3,16
       nn = 4
       imgtitle$ =" MODE 3,16 Ratio "+str$(a,1,2)+" "
     CASE 10
       MODE 4,8
       nn = 4
       a = 0.833 ' aspect ratio used in the CIRCLE command.
       imgtitle$ =" MODE 4,8 Ratio "+str$(a,1,3)+" "
     CASE 11
       MODE 4,12
       nn = 4
       imgtitle$ =" MODE 4,12 Ratio "+str$(a,1,3)+" "
     CASE 12
       MODE 4,16
       nn = 4
       imgtitle$ =" MODE 4,16 Ratio "+str$(a,1,3)+" "
     CASE 13
       MODE 5,8
       nn = 4
       imgtitle$ =" MODE 5,8 Ratio "+str$(a,1,3)+" "
     CASE 14
       MODE 5,12
       nn = 4
       imgtitle$ =" MODE 5,12 Ratio "+str$(a,1,3)+" "
     CASE 15
       MODE 5,16
       nn = 4
       imgtitle$ =" MODE 5,16 Ratio "+str$(a,1,3)+" "
   END SELECT
   'PRINT imgtitle$ ' for debug
   if m = 0 then
     cls
     TEXT 400,100, "Video mode test",cm,5,1
     TEXT 400,180, "Ratio = aspect ratio used in the circle command",cm,1,1
     TEXT 400,220, "Q to quit, P to save page as a BMP",cm,3,1
     text 400,260,"UP arrow to go back, any other key to advance",cm,3,1
   else
     wd = MM.HRES : ht = MM.VRES
     wbox = wd / 8
     FOR x = 0 TO 7
       BOX x*wbox,ht/4,wbox,ht/2,0,c(x), c(x)
     NEXT x
     FOR x = 0 TO wd-1
       sh = 255*x/wd
       LINE x,0,x,ht/12,1,RGB(sh,0,0)
       LINE x,ht/12,x,ht/6,1,RGB(0,sh,0)
       LINE x,ht/6,x,ht/4,1,RGB(0,0,sh)
       LINE x,ht*9/12,x,ht*10/12,1,RGB(0,sh,sh)
       LINE x,ht*10/12,x,ht*11/12,1,RGB(sh,0,sh)
       LINE x,ht*11/12,x,ht,1,RGB(sh,sh,0)
       LINE x,ht/2,x,ht*3/4,1,RGB(sh,sh,sh)
     NEXT x
     CIRCLE wd/2,ht/2, ht*15/32,3,a,c(7)
     sh = 0
     x = wd/2 - 55*nn/2
     FOR w = 10 TO 1 STEP -1
       FOR n = 1 TO nn
         sh = 255 - sh
         LINE x,ht*3/8,x,ht*5/8,w,RGB(sh,sh,sh)
         x = x + w
       NEXT n
     NEXT w
     BOX 0,0,wd,ht,3,c(7)
     BOX 1,1,wd-2,ht-2,1,c(5)
     TEXT wd/2,ht/2, imgtitle$,cm,1,1
   endif
   DO
     k$ = INKEY$
   LOOP UNTIL k$<>""
   IF k$ = "P" OR k$ = "p" THEN
     fname$ = MID$(imgtitle$,2)+".bmp"
     timer = 0
     SAVE IMAGE fname$
    ' mess$ = "Saved as "+fname$+" in "+str$(timer/1000,3,2)+" Sec"
     TEXT wd/2,ht/2,"Saved as "+fname$+" in "+str$(timer/1000,3,2)+" Sec" ,cm,1,1
     DO
       k$ = INKEY$
     LOOP UNTIL k$<>""
   ENDIF
   IF k$ = "Q" OR k$ = "q" THEN EXIT DO
   'PRINT ASC(k$)
   IF ASC(k$) = 128 THEN
     m = m - 1
     IF m < 1 THEN m = 15
   ELSE
     m = m + 1
     IF m > 15 THEN m = 1
   ENDIF
 LOOP
 MODE 1,8 ' restore before ending program
 CLS
panky
Posted: 03:41am 26 Jul 2020
@JoOngle,
If you are getting into the graphics capabilities, you might find this manual on Graphics Programming (which is a collection of all Peter's posts on graphics) helpfull in understanding modes, colours pages, etc. etc.
Graphics Programming on the CMM2-v1.0b.pdf
Doug
panky
Posted: 03:42am 26 Jul 2020
Jim,
May I include your demo program above in the Graphics Programming manual please?
Doug.
Posted: 06:56am 26 Jul 2020
  panky said  Jim,
Doug.
Go for it.
Posted: 07:49am 26 Jul 2020
  Quote  That's right - the blue is missing some shades, 4 of them I think,
Its worth explaining what you were seeing:
The default mode for the CMM2 is 8 bit colour. This is RGB332. i.e. there are 7-levels each of red and green (+ off) + 3 levels of blue (+off).
Switch to 12-bit mode for RGB444 or 16 bit mode for RGB565. All explained in the manual.
JoOngle
Posted: 03:41pm 26 Jul 2020
Hi again, wow - overwhelming response, thanks so much!
Sorry for the late answer but I live in Sweden so there will be some time-zone
differences across the world.
@mkopack73
You're right. I tried changing those right after you explained it, the full colour mode worked just fine with the program. (mode 1,16)
@TassyJim
Awesome, going to try that right away! Thanks for the elaborate code example, I love code examples, that is how I have been learning anything I've messed around with, I like examples so much better as it teaches old dogs new tricks and different aspects of coding.
@panky
Thanks, will read into that manual indeed.
@matherp
Ah, that is SO peculiar to me, well - whatever works - works I guess. I'll have to dive into the manual anyway, right now I'm experimenting around because I like to explore things so I can match my existing knowledge and see how much of it matches MMBasic, so far it's an incredibly pleasant experience.
I love how CMM2 works so far, you guys have outdone yourselves making it both easy and simple and fun to code on this box, love how the function keys makes it a breeze to jump from code to run-time terminal and file system. And I just adore the fact I can simply just either pull the plug or switch it off, and switch it right back on again to continue wherever I was the last time. You guys brought the FUN back in personal computing.
