Local Time 07:14 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sending emails from MM-DOS
Bizzie
Posted: 08:10am 25 Jul 2020
Hi All,
I am wondering if anyone has managed to send emails from MM-DOS?
If so how did you do it?
I have tried running mmbasic from a powershell window and using the system command to set variables Like from here about quarter way down this page. To overcome the string length problem.
For example
system "$PSEmailServer = 'mail......'"
This code sets the variable from the PowerShell command prompt, so it is not a problem with the single quotes.
MM-DOS generates an error
  Quote  Command could not be run
Eventually I want to include some graphics in the email so have not considered using an ESP... WiFi module from a mite.
All thoughts welcome
Rob White
Posted: 09:33pm 25 Jul 2020
Have you tried putting the command into a batch file?
Bizzie
Posted: 10:11am 27 Jul 2020
TassyJim,
Have not tried batch files as I believe they can not be run from powershell. I am battling to get powershell setup to execute its scripts.
Thanks for your reply.
Rob White
