Local Time 17:27 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Confused by Dim...
mkopack73
Posted: 08:53pm 18 Jul 2020
Hey gang,
Ok, my CMM2 arrived today and I've already started digging in writing a couple little test programs... Did one to see how fast a simple bubble sort program is compared to my old C128 (it's LAUGHABLE... C-128 in fast mode takes on avg 3.5 sec to generate and sort 20 integers. CMM2 does it in 10ms!)
I'm confused about 1 thing though...
When using DIM to set up an array and initialize the array with values such as this:
dim integer myarray(5) = (15,25,33,7)
Why does the array size (5 in the above example) have to be 1 LESS than the number of items???) That seems VERY weird to me...
Or is this because I didn't set Option Base to 1?
Either way it seems strange to me because in past BASIC's I've used the myarray(5) would be saying "Set up space for me to put 5 items into the array". Is the variable itself taking up the first spot or something???
hitsware2
Posted: 09:25pm 18 Jul 2020
The first pointer is 0
So for 5 items ... dim(4)
x(0), x(1), x(2), x(3), x(4)
my site
mkopack73
Posted: 09:28pm 18 Jul 2020
  hitsware2 said  The first pointer is 0
Does that change if I set the Option for it to be BASE 1 instead of BASE 0???
mkopack73
Posted: 09:39pm 18 Jul 2020
Ok yeah,  a little testing shows that it depends on how Option Base is set...
Option Base 0:
dim integer test1(4) = (1,2,3,4,5)    - ok
dim integer test2(4) = (1,2,3,4)   - Error not enough initializing values
Option Base 1:
dim integer test1(4) = (1,2,3,4,5)    - error too many initializing values
dim integer test2(4) = (1,2,3,4)   - ok
So, I would say make it a point to ALWAYS specify the option at the top of your program so you know which way it's going to behave...
mkopack73
Option Base 0:
Option Base 1:
hitsware2
Posted: 10:30pm 18 Jul 2020
You got me on that one
I ' ve never used ' option base '
my site
mkopack73
Posted: 10:50pm 18 Jul 2020
It defaults to 0...
So think of the n in the dimension this way:
Option base 0  - n is the last index you want to allow  (the number of items in the array will be N+1)
Option base 1 - n is the # of items in the array (indexes start at 1)
Atomizer_Zero
Posted: 11:20pm 18 Jul 2020
For me, I remember it as:
Option Base 0 - array starts at index 0
Option Base 1 - array starts at index 1
mkopack73
Posted: 11:25pm 18 Jul 2020
  Atomizer_Zero said  For me, I remember it as:
Yes, but you also have to think about what the N in the Dim varname(n) means - it's different depending on which base you use...
GregZone
Posted: 06:22am 19 Jul 2020
  mkopack73 said  Why does the array size (5 in the above example) have to be 1 LESS than the number of items???) That seems VERY weird to me...
The simpliest way to answer this is that when you declare an Array (with DIM) you specify its *highest index*, not the total number of elements in the array.
ie. Don't think of it being an array "size", just think of the highest *index* you will reference.
