Local Time 07:42 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : armcfgenV142.bas strangeness
vegipete
Posted: 10:57pm 12 Jul 2020
I'm working through the MMBasic CSub generator program presented in the CSub for the Colour Maximite 2 thread and I'm having a problem with one of the lines.
In line 275, the variable 'm' first appears. But the usage makes no sense.
275  for j=0 to m-1
276    if s$=symbols$(j,1) then
277      if k<>0 and mode then print #2,""
          'The last function didn't end with a newline so output one
278        dat$=symbols$(j,2)
279        m=instr(dat$,".")
280        dat$=left$(dat$,m-1)
281        print #2,chr$(9)+"'"+dat$
282        k=0
283      endif
284  next j
'm' also appears in lines 279 and 280.
This variable is never defined or given a value earlier so it should have the value 0. Which means the "for j = ... next j" loop will never happen.
Is it just dead code or a typo or?
Thanks for any insight.
Posted: 12:13am 13 Jul 2020
Perhaps "m" in line 275 should be "mm" as in other loops, the number of symbols in the symbol table.
Edited 2020-07-13 10:14 by lizby
vegipete
Posted: 12:22am 13 Jul 2020
That could well be. Higher up, on line 217, that is exactly the case.
  for j=0 to mm-1
Posted: 07:19am 13 Jul 2020
Thanks for the spot but as if happens this code doesn't seem to be run for the ARM compiler. For the PIC the compiler puts static data into a section .rodata, but the ARM compiler seems to leave it in .text so the code is never used. I'll fix it anyway when I post the next version of the CMM2 firmware
