Local Time 07:42 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "variable already defined"?
Tinine
Posted: 05:44pm 09 Jul 2020
Not sure if the above message is verbatim because I'm away from my system.
Executing my program and I decide to break out. This is in MM Edit.
I want to use "chat" to run a function or a sub but I get the error shown in the subject.
Pretty sure it sometimes works OK but naturally, not when I really need it.
Have I messed up or am I missing something?
Craig
Edited 2020-07-10 03:45 by Tinine
Posted: 06:15pm 09 Jul 2020
This gives it; can it be something related?
DOS MMBasic Ver 5.05.02
Copyright 2011-2019 Geoff Graham
> i%=1
> i$=1
Error: I already declared
Tinine
Posted: 07:29pm 09 Jul 2020
  lizby said  This gives it; can it be something related?
> i%=1
> i$=1
Oh, I should have been more specific.
SUB MySub(MyParam)
Do Something
End Sub
In "Chat", I type "MySub 5" and I get the error that MyParam is already defined.
Craig
Edit: Oh it probably is declared, not defined.
Edited 2020-07-10 05:31 by Tinine
Posted: 07:53pm 09 Jul 2020
Curious. In MMBasic DOS, this works for me:
> list
mysub(5)
End
Sub mysub(x)
Print x
End Sub
> run
5
> mysub 3
3
But with an undeclared variable:
> mysub A
[3] Sub mysub(x)
Error: X already declared
Or with the wrong type:
> mysub "9"
Error: Incompatible type: "9"
Edited 2020-07-10 06:03 by lizby
Tinine
Posted: 12:33pm 13 Jul 2020
I have been revisiting this and I can make it work if I ERASE the "already declared" variable in chat before calling the procedure.
