Local Time 17:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to use bit manipulation
Canada_Cold
Posted: 03:32pm 06 Jul 2020
Hi All,
I’m trying to understand how to use bit manipulation on an Micromite 28 pin device.    In the statement “PRINT HEX$(X%, 16)” what does the second parameter “16” do?
The following is from the Micromite User Manual, MMBasic Ver 5.05, Page 38
X% = &HFFFF0000FFFF0044
Y% = &H800FFFFFFFFFFFFF
X% = X% AND Y%
PRINT HEX$(X%, 16)
I have tried changing the parameter, but it does not change the printed results.
I appreciate any help you can give me with this.
Don
Posted: 03:35pm 06 Jul 2020
Try hex$(4) and hex$(4,16)
Posted: 04:13pm 06 Jul 2020
it controls padding with zeros to the left. if your number can be represented in less than 16 digits, then it will be padded with leading zeros. try the following:
X% = &HFFFF0000
Y% = &H800FFFFF
X% = X% And Y%
Print Hex$(X%, 16)
Print Hex$(X%, 8)
> run
00000000800F0000
800F0000
rob   :-)
Canada_Cold
Posted: 09:22pm 07 Jul 2020
Hi guys,
Thanks for the input, that’s great.
Thanks, Don
