Local Time 08:22 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Minimum requirements for a basic ArmmiteF4
Glen0
Posted: 02:14am 27 Jun 2020
I find the micromite quite useful as a switchmode power supply controller, in the development phase, but when it comes to making a fully functional one the more speed the better.
Has anyone made up a basic F4 using the same chip as found on the ArmmiteF4 board?
Turbo46
Posted: 05:22am 27 Jun 2020
  Quote  Has anyone made up a basic F4 using the same chip as found on the ArmmiteF4 board?
Is this what you are looking for?
Glen0
Posted: 06:49am 27 Jun 2020
Thanks Bill
That's the ultimate. I have some of those and they appear to be nearly 4 times faster than the 28 pin micromite.
I was however looking at using the chip mounted on a breakout type pcb and using the bare minimum components so that I can use a few A/D pins and about 4 PWM pins. Just.... "need the speed"
Posted: 07:10am 27 Jun 2020
All you need is the chip, a bunch of capacitors and two crystals. Search for minimum circuit in the ST docs. The RTC crystal is essential but you don't need a battery unless you need the clock to keep time otherwise just tie VBAT to VCC
