Local Time 08:37 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 cange the VGA output pins
Technikfreak6502
Posted: 07:15am 11 Jun 2020
Hello at all!
Is ist possible to change the VGA output pins in the CMM2 firmware?
I have two Nucleo H7 boards and cant use VGA on them. The Waveshare board is almost impossible to buy here in germany.
Maybe it is possible via an OPTION command. So no special firmware is needed.
Would be nice to have this option.
If you release the source, i would also try it myself.
Thanks!
Posted: 07:32am 11 Jun 2020
The VGA signal is generated by a dedicated graphics processor built into the STM32 chip (called the Chrom-ART graphic accelerator).
I don't think there any options to change the pins used.
Posted: 09:26am 11 Jun 2020
  Quote  s ist possible to change the VGA output pins in the CMM2 firmware?
No: not enough pins
If you can't get a Waveshare contact WhiteWizzard on micromite.org. He can supply a ready to run CMM2 based on the single board design and is UK based so easy shipping
Technikfreak6502
Posted: 10:12am 11 Jun 2020
  matherp said
No: not enough pins
You mean the wrong pins?
A quick look over the CMM2 schematic shows around 70 used pins on this 176 pin package.
so you are wasting most of its pins anyway.
As far as i understood you use the Chrom-Art with the LTDC Controller to generate the VGA signal. Sure this has specified pins on each package but it is avialable on the Nucleo.
It seems that most used pins are also avilable on the nucleo.
Posted: 10:22am 11 Jun 2020
  Quote  A quick look over the CMM2 schematic shows around 70 used pins on this 176 pin package.
If you read the CMM2 thread before posting you would see this isn't the case
https://www.thebackshed.com/forum/uploads/panky/2020-05-08_153553_CMM2-GPIO&CPU%20module%20pin%20usage.pdf
Technikfreak6502
Posted: 10:36am 11 Jun 2020
Ok Thank you for the information.
i got the CMM2_Construction_Pack.zip an there only a few pins are used.
