Local Time 08:36 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Dimming The Display
Andrew_G
Posted: 10:50pm 07 Jun 2020
Hi All,
Is is possible to dim the VGA display (similarly to PWM on LCD's)?
Yes, you can do it on the monitor's controls but I am thinking of using a Light Dependent Resistor, as I do on my LCDs, or via an IR command (as well as keyboard etc).
Cheers,
Andrew
(I don't have a CMM2 yet)
Posted: 10:58pm 07 Jun 2020
Depending on the display mode you are in,
You could use the MAP command to change the colour intensity.
You would need a number of sets of colour, one for each of the different light levels.
Andrew_G
Posted: 12:04am 08 Jun 2020
Thanks Jim.
Andrew
