Local Time 17:55 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Bug reports
     Page 1 of 17
Posted: 07:38am 17 May 2020
Rather than multiple different threads, please post all any any bug reports to this thread so I can manage them more easily.
As always bugs are easiest to find when simple example programs are posted. thwill is setting a wonderful example of exactly how to do this.
Known issues at the moment:
error in ERROR command
input$ reading 1 character past the end of a file
As and when I create new releases I will post a message on Geoff's original thread to say they are ready for download.
Please post all documentation issues on the manual errata thread
Edited 2020-05-17 17:41 by matherp
Posted: 02:15pm 19 May 2020
BUG in select & delete/copy/cut multiple lines
To reproduce
1. Edit:
Option Explicit On
Dim a(10) = (0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10)
Cls
print_array()
End
Sub print_array()
 Local i
 For i = 0 To 10
   Print a(i)
 Next i
End Sub
2. Move cursor to empty line before Cls
3. Press F4 to start selection
4. Move cursor down to start of line containing End
5. Press Delete
Actual behaviour
Nothing is deleted.
The status area displays the message "Nothing to delete".
The cursor returns to the line at the start of the selection.
Expected behaviour
The selected lines should be deleted.
Additional
It also doesn't work if you try to copy or cut a selection beginning with an empty line.
Edited 2020-05-20 00:20 by thwill
Posted: 02:25pm 19 May 2020
My beta testers have let me down badly. Perfect bug report thanks - now I just need to work out how to fix it
Posted: 03:42pm 19 May 2020
No known bugs as at V5.05.02RC32 - lots more unknown to find I'm sure
Posted: 03:59pm 19 May 2020
Great, I'll flash it later and if the family let me I'll find some more bugs to keep you company - I saw a doozy earlier but you probably don't want 1000 lines of code to reproduce it
Did you check whether Triangle allows colour & fill to be scalar even when the vertices are arrays ?
Edited 2020-05-20 01:59 by thwill
Posted: 04:01pm 19 May 2020
  Quote  Did you check whether Triangle allows colour & fill to be scalar even when the vertices are arrays ?
The code appears to say yes but if you can prove otherwise then I'll certainly look at it
Posted: 11:32pm 19 May 2020
Here is that doozy I promised
BUG in array state after running via editor
To reproduce
1. Create file "array_bug.bas":
Cls
Dim a(255)
Print "a(0) ="; a(0)
2. At the > prompt
run "array_bug.bas"
3. As expected it outputs
a(0) = 0
4. At the > prompt
Print a(0)
5. As expected it outputs
0
6. At the > prompt
edit "array_bug.bas"
7. F2 - to run
8. As expected it outputs
a(0) = 0
9. At the > prompt
Print a(0)
Actual behaviour
Outputs
4.777888813e+104
Expected behaviour
Outputs
0
Posted: 07:51am 20 May 2020
Thanks for the report and great example. This is a cache coherency bug. When a program ends the firmware executes a longjmp command. When this command is used cache must be flushed first. In most places in the code I had done this but not when a program just runs off the end of the Basic statements or with an END statement. This will be fixed in the next beta.
Basically the running program has written to the a() array but this information is currently held in cache. This isn't an issue in the program because when we read the a() array the chip knows that the data is in cache and reads it from there. If the program was bigger other data would end up in cache and the chip would know it had to write the old cached information back to real memory and you wouldn't see the bug.
UPDATE
Wasn't just a caching issue; something much more stupid on my part - fixed ready for posting once I sort out another minor issue.
Edited 2020-05-20 21:33 by matherp
Posted: 10:43pm 20 May 2020
Multiple bugs when using array parameters to graphic primitive commands
See: graphics_errors.bas.zip
1. CIRCLE leaves uncoloured pixels at perimeter
2. CIRCLE when called with array coordinates but scalar colors does weird sh*t
3. RBOX when called with array coordinates but scalar colors does weird sh*t
4. TRIANGLE when called with array coordinates but scalar colors reports "Error: Dimensions"
Also note comment about the documented type of the coordinate parameters to Polygon compared with the other graphic primitives.
Posted: 10:48pm 20 May 2020
Unclosed subroutine does not report an error
Surely the following program should report an error when run:
Cls
foo()
bar()
Sub foo()
 Print "foo"
Sub bar()
 Print "bar"
End Sub
Posted: 12:07pm 21 May 2020
Thanks for the reports - the last one is for Geoff. I don't touch MMBasic   I'll copy him separately.
All the rest of the graphics ones are also in the ArmmiteH7, the ArmmiteF4, and the MMX. The circle pixel one is also in every Micromite. Mostly just trivial cut and paste errors. just shows how many people have tried using arrays as inputs to graphics routines!
All will be fixed in RC35 to be posted later today
Posted: 12:24pm 21 May 2020
  matherp said  Thanks for the reports
You're welcome.
  Quote  - the last one is for Geoff. I don't touch MMBasic
I'm not sure I understand the distinction, are not all the other bugs I've reported problems with MMBasic (on the CMM2) ?
  Quote  All will be fixed in RC35 to be posted later today
Great.
I've got a USB keyboard coming today, expect to be baraged with reports (and I can't help myself, suggestions) related to the editor ... I've been holding off until now just in case the problems I'm having are due to using the serial console.
Posted: 05:53pm 21 May 2020
No known functional bugs as at V5.05.02RC35 - still lots more unknown to find I'm sure
Unclosed subroutine does not report an error exists in all versions of MMBasic and is on Geoff's to-do list but at low priority
  Quote  expect to be baraged with reports (and I can't help myself, suggestions) related to the editor
NB the likelyhood of changes to the editor other than bug fixes are vanishingly small
Edited 2020-05-22 04:04 by matherp
Posted: 07:52pm 21 May 2020
  matherp said  NB the likelyhood of changes to the editor other than bug fixes are vanishingly small
Understood, but likewise it is in the nature of published works to be subject to critique.
Posted: 10:33pm 21 May 2020
As promised ...
Issues with the editor
1. Double pressing [End] does not consistently take you to the end of the document, sometimes it just goes to the end of the line. Double pressing [Home] seems to work as advertised. To reproduce open a multi-page .BAS file and navigate around it with [Page Up|Down], [Home] and [End], eventually you should find yourself in a situation where double pressing [End] does not go to the end of the file. If you cannot reproduce then I'll provide you with a .BAS file and exacting instructions.
2. If you hold down [Up] or [Down] and scroll beyond the start end of a page for a bit and then release the key the page keeps scrolling; presumably until the keyboard buffer empties ... this is very annoying. If you try the same experiment on a CMM then releasing the key immediately stops the scrolling.
3. You can't use [Page Up], [Page Down] and double pressing [Home] and [End] to navigate whilst doing an F4 selection. Possibly this is a deliberate omission, but it's not very friendly.
4. I believe the "Save As" behaviour is unconventional and at the very least misnamed. Most (All?) editors would save the file you are working on to the new file AND switch so that you were editing that new file. The existing behaviour corresponds more to a "Copy File" or "Backup File" command as it leaves you editing the original. It leads to the strange workflow that if you've already made some changes that you want to keep but you don't want to overwrite the original just yet then you have to "Save As" and [Escape] out of the editor to avoid your changes going into the original.
5. OK, this is a feature request and I know how you feel about those, but something really useful is a shortcut that comments/uncomments all the lines currently selected.
Hope this helps,
Edited 2020-05-22 08:34 by thwill
Turbo46
Posted: 03:06am 22 May 2020
  Quote  I believe the "Save As" behaviour is unconventional and at the very least misnamed. Most (All?) editors would save the file you are working on to the new file AND switch so that you were editing that new file.
Again, I have to agree with Tom on this. The behaviour in not as you would expect and will surely be a "gotcha" in the future. The first thing I do when editing a program is to do a SAVE AS so I know the original is safe. It WILL catch me out.
  Quote  something really useful is a shortcut that comments/uncomments all the lines currently selected.
MMEdit does this, and it IS handy.
Posted: 09:21am 22 May 2020
  Quote  1. Double pressing [End] does not consistently take you to the end of the document, sometimes it just goes to the end of the line. Double pressing [Home] seems to work as advertised. To reproduce open a multi-page .BAS file and navigate around it with [Page Up|Down], [Home] and [End], eventually you should find yourself in a situation where double pressing [End] does not go to the end of the file. If you cannot reproduce then I'll provide you with a .BAS file and exacting instructions.
Will fix
  Quote  2. If you hold down [Up] or [Down] and scroll beyond the start end of a page for a bit and then release the key the page keeps scrolling; presumably until the keyboard buffer empties ... this is very annoying. If you try the same experiment on a CMM then releasing the key immediately stops the scrolling.
Can significantly improve this but probably not solve completely as characters are buffered all over the place when using teraterm over usb with USB buffering, key repeat algorithm , keyboard buffer etc.
  Quote  3. You can't use [Page Up], [Page Down] and double pressing [Home] and [End] to navigate whilst doing an F4 selection. Possibly this is a deliberate omission, but it's not very friendly.
The selection code is too complex to allow this as there are so many special cases that bugs are inevitable
  Quote  4. I believe the "Save As" behaviour is unconventional and at the very least misnamed. Most (All?) editors would save the file you are working on to the new file AND switch so that you were editing that new file. The existing behaviour corresponds more to a "Copy File" or "Backup File" command as it leaves you editing the original. It leads to the strange workflow that if you've already made some changes that you want to keep but you don't want to overwrite the original just yet then you have to "Save As" and [Escape] out of the editor to avoid your changes going into the original.
Could rename but will not change the concept, would need huge destabilising change as it interacts with concept of current file and how programs are stored and managed for execution
  Quote  5. OK, this is a feature request
Correct
We are coming up to the formal release of the CMM2 in SC. My overriding concern is stability of the code and finding/fixing real bugs not perceived deviations from some other norm. I cannot and will not be making functional changes that could impact that stability. Anything relating to the editor/file handling comes into that category.
Once the code is released then it will go into a normal development cycle and functional changes could then be incorporated but that will happen on a periodic basis (6 month or a year) with each release following an extensive beta period
Posted: 10:05am 22 May 2020
Acknowledged.
Note that the scrolling/keyboard buffer problem is present when using the CMM2 over VGA and not just through a serial terminal.
I think renaming "Save As" might be wise but understand (if regret) that it cannot be made to adhere to convention.
Turbo46
Posted: 11:32am 22 May 2020
  Quote  I think renaming "Save As" might be wise but understand (if regret) that it cannot be made to adhere to convention.
+1
Perhaps something for the future?
Posted: 12:22pm 22 May 2020
See main thread for RC36 changes
     Page 1 of 17
