Local Time 17:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : " This is a Windows NT character-mode executable "
hitsware2
Posted: 01:16pm 07 May 2020
Trying to run MMBasic in DosBox .
BBCBasic works OK .
my site
Frank N. Furter
Posted: 07:28am 08 May 2020
Why in DosBox? It's a Windows executable program not a DOS program...
Frank
Posted: 11:31am 08 May 2020
Might work with WINE
hitsware2
Posted: 12:18pm 08 May 2020
No Wine for Raspberry Pi ....
Edited 2020-05-08 22:18 by hitsware2
my site
hitsware2
Posted: 12:24pm 08 May 2020
  Frank N. Furter said  Why in DosBox? It's a Windows executable program not a DOS program...
Frank
The Windows/DOS version of MMBasic was created to make it easy to evaluate MMBasic.  It is a single executable that does not need installation, just double click on the executable and MMBasic will run in a DOS window on Windows (including Windows 10).
Duh ... Got confused by the " Dos window "
my site
Frank N. Furter
Posted: 01:21pm 08 May 2020
There used to be EXAGEAR for the Raspberry - unfortunately that no longer exists.
Maybe this video  will help?
Frank
hitsware2
Posted: 01:48pm 08 May 2020
Thank You ! ... Too complicated for me .
Was just doing it for fun anyways .
DosBox is quite groovy though
my site
Posted: 05:55pm 08 May 2020
Frank
"will run in a DOS window on Windows": it is NOT a DOS window.
it is a win32 console window that runs win32 applications. while there is a compatibility layer built in to allow running real-mode MSDOS applications, i'd be surprised if many such applications even still exist. and MMbasic is not such an application.
DOSBOX emulates a 386 processor and MSDOS. it is incapable of running win32 applications. it can run real-mode MSDOS applications, including those that switch into protected-mode to access memory beyond the 1mb boundary and make use of 386 instructions.
just to make it perfectly clear, there is NO SUCH THING as MMbasic for DOS. people might call it that, but this is wrong. there is MMbasic for win32 console mode. this is a windows application, NOT a DOS application, that has no GUI abilities and can only run in the console window provided by windows.
rob   :-)
Posted: 06:03pm 08 May 2020
  hitsware2 said  No Wine for Raspberry Pi ....
Wasn't apparent you were referring to RPi...
hitsware2
Posted: 06:43pm 08 May 2020
Yes .... My PC is RPi 3B+ ....
my site
hitsware2
Posted: 06:46pm 08 May 2020
> Just to make it perfectly clear,
> for DOS.
Got'cha
my site
