Local Time 17:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can I save a screen image using a micromite backpack
snarf
Posted: 08:06pm 30 Apr 2020
I am making a project with the Micromite Backpack V2 with the latest version of MM basic.
This is my first programming project and am still coming to grips with MMBasic.
The screen displays various values but has a cumulative graph for upto 10 hours. At times I need to switch to another screen to make and save PID value adjustments, then switch back to the main screen. If I can save a screenshot before switching to the adjustment screen, I could load it again when I switch back so not loosing the historical graph.
Haven't come to grips with arrays or saving data to eeproms, and was wondering if the was a simple answer? I see a SD card holder under the screen.
Ant help would be appreciated.
Thanks, snarf
palcal
Posted: 08:44pm 30 Apr 2020
I think you would need MM Plus. Download the MM Plus manual. Look at Pg 41. You can also save Bitmap to SD card.
I sent you a PM look in your inbox.
Edited 2020-05-01 07:56 by palcal
Posted: 10:47pm 30 Apr 2020
  snarf said  wondering if there was a simple answer?
I think on your present equipment there's no hope for saving a screen shot and restoring it. Probably best to figure out how to save the data needed to re-create the screen.
Posted: 11:49am 01 May 2020
Hi snarf,
The backpack V2 uses a 28pin MX170 chip running MMbasic2.
In MMbasic2 there is no simple way to make use of the SD card. Matherp wrote a Cfunction that can be used to write data to the SD card but there are limitations.
AFAIK there is no way to take a screenshot in MMbasic2.
If you draw a graph on the screen you do that from numerical data in your PID controller. This numeric data can be extracted through the serial port. The same connection you use to program the chip.
Example: create an array of the last feedback values (feedback represents the actual output of the PID algorithm).
As part of your program you could (on key press) simply print all the 100 values (to the serial port).
dim feedback(100)
if inkey$="d" then
for i=1 to 100
print feedback(i)
next i
end if
Your PC could log the values in a "values.csv" file that can be read in Excel.
Excel can make you the nice graphs.
You can make your file as large as memory allows, capturing as much of the process as required.
Posted: 06:21pm 01 May 2020
Get to grips with arrays, they aren't difficult
Lets assume you are writing to the array with time on the X axis. As you are writing data to the display save the data to an array in an element representing the x-coordinate with a value equal to the Y coordinate. Then after you have done your pidding just write each element back to the display.
dim x%(319)
'logging here
x%(column_number)= row_number
sub restore
for i=0 to 319
pixel i,x%(i)
next i
end sub
palcal
Posted: 10:29pm 01 May 2020
Matherp wrote
  Quote  Then after you have done your pidding
Haven't heard of "pidding" before, what does it mean.
Posted: 10:37pm 01 May 2020
It's about "PID value adjustments".
Posted: 10:38pm 01 May 2020
Reread the first post
He wants to use another screen to change PID values, hence PIDing
Edit:
John beat me - too slow typing!
Edited 2020-05-02 08:39 by TassyJim
palcal
Posted: 11:02pm 01 May 2020
OK got it. Maybe I would have understood PIDing.
Edited 2020-05-02 09:04 by palcal
Posted: 11:06pm 01 May 2020
  palcal said  OK got it. Maybe I would have understood PIDing.
Cold and wet here today so PIDdling is more like it.
palcal
Posted: 11:52pm 01 May 2020
Sunny and 30 degrees here.
Phil23
Posted: 12:59am 02 May 2020
I guess it is like the Plusing some kids did in Primary School.
Some also said they got the wrong answer even they Plused the numbers...
palcal
Posted: 01:14am 02 May 2020
Yeh, I looked it up in the dictionary then Mr Google didn't know so thought I would ask.
snarf
Posted: 06:44am 02 May 2020
Hey Guys,
Thanks for all of your advice and confirming that there is no "easy way".
Matherp, I should take the next step, and make sense of arrays.  I see your suggestion as a good solution.
Once the PID values are OK, I shouldn't need to access the adjustment screen again (I hope), hence was hoping for a simple screen shot/restore answer.
Again, thanks, and hope you are all managing & keeping well.
Social distancing being relaxed a little here today in Qld, Aust.  Got to hug the grandchildren.
Rod
Cyber
Posted: 02:26pm 04 May 2020
  Volhout said  The backpack V2 uses a 28pin MX170 chip running MMbasic2.
Where can I find this function? And some usage info.
I understand about limitations, but it might satisfy my needs.
Posted: 02:45pm 04 May 2020
Maybe https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12013
Into a web search I put
matherp thebackshed cfunction sd read write
There were more results in case that's not the one.
Cyber
Posted: 03:10pm 04 May 2020
  JohnS said  Maybe https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12013
Looks like it. Thanx, John!
Posted: 03:43pm 04 May 2020
Hope it works :)
