Local Time 17:27 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial Com issue
jovian
Posted: 01:17am 22 Apr 2020
Hi all
I've been wrestling with the serial comms between 44pin micromite ver 5.0302 and an FN-RM01 FN RM01  audio record and playback board.
I have two boards, they both play back when manually keyed. But I can't seem to get them to play back using UART from either COM port on the mite.
Manual for the board states:
4.1. Serial Communication Protocol
FN-RM01 supports standard UART asynchronous serial control(communication baud rate is 9600bps), working at 3.3V TTL level. Possible to be converted to RS232 level via MAX3232 chip. The communication protocol format is as below.
Start code: 0x7E
Number: number of bytes from Number itself to check code
Command: a specific serial command byte
Parameter: to realize a specific function with a command byte together
Check code: it’s a sum value of Number+Command+Parameter(it uses one byte only that is from the lower 8 bits)
End code: 0x7E
If use a serial assistant, you need to set the parameters correctly as below.
Note: All of the commands need to be sent in hex.
Example is:
.3.1. Specify playback(of a file) by indexed sequence in the root directory of the storage device
This command is to play the 1st sound file in the root directory of the storage device.
Returned data: 00 represents command is executed successfully; 01 represents no this file.
Start Code 7E
Number 05
Command A2
MSB of the Sound File 00
LSB of the Sound File 01
Check Code A8
End Code 7E
MY CODE IS:
OPEN "COM1: 9600" AS #1
PAUSE 100
PRINT #1,&H7E05A20001A87E
DO
INPUT #1, A$
IF A$<>"" THEN
PRINT A$
A$=""
ENDIF
LOOP
END
'7E,05,A2,00,01,A8,7E ;PLAY FILE 1
I cannot get the board to respond.. I have two boards and the behaviour is the same on both. Any ideas before I hurl the thing into the circular file?
Many thanks,
Joe
panky
Posted: 01:32am 22 Apr 2020
Joe,
I think the statement in your notes
  Quote  Note: All of the commands need to be sent in hex.
means you need to send hex ASCII characters, so your PRINT #1 line might need to be
PRINT #1,"7E05A20001A87E";
Note the semiocolon on the end to supress CRLF.
I don't have one of the modules so I can't test but you might like to try this.
Doug.
Edited 2020-04-22 11:42 by panky
Posted: 01:54am 22 Apr 2020
A common problem.
I would expect it to require hex values:
Start Code 7E
Number 05
Command A2
Check Code A8
End Code 7E
PRINT chr$(&H7E)+chr$(&H05)+chr$(&HA2)+chr$(&H00)+chr$(&H01)+chr$(&HA8)+chr$(&H7E);
You may or may not need the trailing CRLF
jovian
Posted: 03:15am 22 Apr 2020
Doug, Jim
Thank you kindly for your fast responses.
Jim, your solution worked! Thank you very much.
For the record, somewhat strangely to me
A$=chr$(&H7E)+chr$(&H05)+chr$(&HA2)+chr$(&H00)+chr$(&H01)+chr$(&HA8)+chr$(&H7E)
PRINT #1,A$
doesn't work, but exactly as you notated it does:
Thanks for your help, I almost didn't have any hair left to pull out!
Cheers all
Joe
jovian
Posted: 03:44am 22 Apr 2020
Hi all
FWIW the solution to the Micromite UART Com1 serial communication issue above is that in this instance with the FN-RM01 board, and maybe others, the trailing semicolon is crucial. Thus the following works, but fails without the trailing semicolon:
PRINT #1,A$;
Joe
Posted: 05:12am 22 Apr 2020
The trailing semicolon prevents the CRLF from being sent.
A lot of devices get very confused if they receive extraneous data while others can handle it OK.
Some need all the data sent in one stream while others can handle slow drip feeding.
Some require you to use two stop bits to give them time to digest the data.
It all makes life interesting...
jovian
Posted: 05:13am 22 Apr 2020
Very useful information, thanks!
Phil23
Posted: 10:09pm 22 Apr 2020
This may??? also work; setting up a few Constants....
Constant Play$=chr$(&H7E)+chr$(&H05)+chr$(&HA2)+chr$(&H00)+chr$(&H01)+chr$(&HA8)+chr$(&H7E)
PRINT #1,Play$;
Would need testing, but if it worked, you could setup Constants for all the strings you need to send.
Cheers.
Edit:- pointless reply as Play$ = Jim's A$.....
Must be the stir crazy Covid isolation & boredom setting in...
Edited 2020-04-23 08:12 by Phil23
