Local Time 09:31 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2 random number on startup
GoodToGo!
Posted: 11:04pm 02 Apr 2020
Howdy all,
I hope you are all well in these trying times.
I have multiple LED lighting modules powered by E28's that are designed to flash 3-wire Xmas lights. As a part of the Basic routine, there are multiple sub-routines with the flashing sequences. Upon startup I seed the Random generator with the Timer and then use it to select 1 of the 5 routines as a starting point. Reason being I don't want all the modules to start at the same routine. Great in theory, doesn't work in practice due to all modules seeding the same timer time of course.
I was thinking of maybe using a 'programming resistor' and measure the analog input voltage and use that as a seed? Different resistors should give different voltages, meaning different seed values meaning different random numbers meaning different starting points....
Can anyone else think of a way to generate differing random numbers on module start?
Cheers,
GTG!
OA47
Posted: 12:08am 03 Apr 2020
GtG, could you use the onboard clock to supply current uS value to start as your seed?
OA47
Phil23
Posted: 02:06am 03 Apr 2020
How many E28 Modules?, And I'm Guessing they don't talk to each other.
Just boot & then run one of the 5 sequences & then switch to an alternate random one after a random time?
Turbo46
Posted: 06:11am 03 Apr 2020
Could you have a 'start' button for each that you must press to start the sequence? That would add randomness to the startup.
CaptainBoing has discussed random number generation using a noise generator on the Fruit of the shed, see here and here. You can find more circuits on the web.
Posted: 06:50am 03 Apr 2020
> AUTOSAVE
spare = 23 ' any spare analog pin left floating.
setpin spare, ain
RANDOMIZE pin(spare)*1000
print rnd()
Saved 53 bytes
> RUN
0.300794
> RUN
0.0807553
> RUN
0.830729
> RUN
0.62072
> RUN
0.270705
> RUN
0.170715
> RUN
0.370797
GoodToGo!
Posted: 07:43am 03 Apr 2020
  Quote  GtG, could you use the onboard clock to supply current uS value to start as your seed?
I originally did, using RANDOMIZE(TIMER). But because all the E28's are connected to the same time switch, they all appeared to use the same TIMER value.
  Quote  How many E28 Modules?, And I'm Guessing they don't talk to each other.
5 so far, they are all independent except for their power source which is switched on by a 230VAC timer. They all run through the sequences in turn, and then repeat.
  Quote  > AUTOSAVE
setpin spare, ain
print rnd()
Saved 53 bytes
> RUN
0.300794
> RUN
0.0807553
> RUN
0.830729
> RUN
0.62072
> RUN
0.270705
> RUN
0.170715
> RUN
0.370797
Jim, that's perfect! I did try using a high-ish value resistor between pin 7 and the 3.3v supply, which worked, but I also found it worked with the resistor removed! Much better than seeding from the TIMER value in my case.
Thanks for all your help everyone!
Cheers,
GTG!
