Local Time 09:32 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM only getting 4.7V from CON 6 pin 23
Posted: 02:13pm 28 Mar 2020
Hi folks,
On my Colour Maximite the 5V line from CON 6 (the 26 pin GPIO) is only supplying 4.7V. Is this to be expected?
The CMM is being powered via USB from a Raspberry Pi 3.
I've tried a couple of USB wall-warts too and with those I only get 4.3 - 4.6V
Posted: 09:10pm 28 Mar 2020
That sounds about right.
There is a diode in the 5V supply line which will account for the less than 5V you are seeing.
Posted: 10:23pm 30 Mar 2020
Thank you Jim.
Regards, Tom
