Forum Index : Microcontroller and PC projects : MM Backpack Help Touch calibration not sticking
| snarf Newbie Joined: 16/03/2020 Location: AustraliaPosts: 4 |
I am trying for the first time to use the MM backpack V2 (28 pin), and have produced some code to set up buttons successfully. I am trying to configure the touch command for them and get > run [98] If Touch(X) <> -1 And Touch(Y) > 198 Then GoSub KEYPRESS Error: Touch not calibrated I then successfully run GUI calibrate, but then get the same result when I run the program again from the MM Chat window. I have loaded and successfully run 2 demo programs that draw touch buttons on then screen. The touch function works perfectly well on both of them. Here is the bit of code that I have written. Hope someone can give me some help why the calibration is not being saved in the MM. 'Rod's Smoker Damper Controller v1 ProbeTemp = 150 SetTemp = 100 CountdownTimer = 9 CountdownTimerBackgroundColour = RGB(Black) OPTION LCDPANEL ILI9341, L, 2, 23, 6 option touch 7, 15 timer = 200000 ' remove when not needed 'add background colour for full screen and remove box from welcome 'welcome text 160, 40, "Welcome David", CM, 1, 3, RGB(White), RGB(blue) text 160,120, "You're", CM, 1, 3, RGB(White), RGB(blue) text 160, 160, "Smokin..", CM, 1, 4, RGB(White), RGB(blue) ' pause 5000 cls 'draw boxes rbox 5, 5, 200, 60, 10, rgb(blue), RGB(yellow) 'oven temp box rbox 212, 5, 101, 60, 10, rgb(blue), RGB(yellow) 'settemp box rbox 5, 67, 310, 18, 10, rgb(blue), RGB(yellow) 'comment box box 5, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'set temp up box box 45, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'set temp down box box 85, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'countdown timer up box box 125, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'countdown timer down box box 165, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'start box box 205, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'pause box box 245, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'end box box 285, 198, 36, 40, 1, rgb(blue), RGB(yellow) 'cancel alarm box rbox 212, 87, 101, 18, 1,rgb(blue), RGB(Yellow) 'countdown timer box 'add text to boxes text 20, 10, "Oven", L, 1, 2, RGB(WHITE), RGB(yellow) text 20, 35, "Temp", L, 1, 2, RGB(WHITE), RGB(yellow) TExT 100,10, str$(ProbeTemp), L, 1, 4, RGB(BLACK), RGB(green) ' displays oven temp text 220, 20, "Set", L, 1, 1, RGB(WHITE), RGB(yellow) text 220, 35, "Temp", L, 1, 1, RGB(WHITE), RGB(yellow) TExT 260,20, str$(SetTemp), L, 1, 2, RGB(BLACK), RGB(green) ' displays set temp TEXT 20,70, "Enter Set Temp & Countdown Timer", L, 1, 1, RGb(Black), RGB(Yellow) 'message line TEXT 10, 200, "Set", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 8, 212, "Temp", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 6, 224, " Up", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 49, 200, "Set", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 47, 212, "Temp", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 47, 224, "Down", L, 1, 1, RGB(Black), RGB(Yellow) 'to do interupts & touch buttons TEXT 87, 207, "Time", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 87, 219, " Up", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 127, 207, "Time", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 127, 219, "Down", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 167, 212, " Go", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 207, 212, "Paus", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 250, 212, "End", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 286, 207, "Stop", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 286, 219, "Alrm", L, 1, 1, RGB(Black), RGB(Yellow) TEXT 214,88, "End", L, 1, 1, RGb(Black), RGB(Yellow) TEXT 285,88, "Hrs", L, 1, 1, RGb(Black), RGB(Yellow) CountdownTime = CountDownTimer - (timer/120000) ' converts millisecs to hours 'If no countdowntimer set then countdown is blanked, or countdowntime is calculated if countdowntimer is set to > 0 if CountdownTimer = 0 then rbox 212, 87, 101, 18, 1, rgb(black), CountdownTimerBackgroundColour 'countdown timer box set to black end if if CountdownTimer > 0 then text 250, 88, STR$(CountdownTime, 1, 1 ), L, 1, 1, RGB(Black), RGB(Green) 'poke countdown timer value into box endif 'setting up touch buttons if touch(X) <> -1 and TOUCH(Y) > 198 then gosub KEYPRESS sub keypress IF 41 > TOUCH(X) > 5 then SetTemp = SetTemp + 1 if 45 > touch(X) >81 then SetTemp = SettTmp - 1 if 85 > Touch(x) >121 then CountdownTimer = CountdownTimer + 1 IF 125 > touch(x) > 161 then CountdownTimer = CountdownTimer - 1 IF 165 > Touch(x) > 201 then print 100 if 205> touch(x) > 241 then print 100 if 245 > touch(x) >281 then print 100 if 285 > touch(x) >212 then rint 100 end sub |
You appear to have OPTION LCDPANEL ILI9341, L, 2, 23, 6 option touch 7, 15 in your code. This should only be done from the command prompt once. It is because you run the commands in your program that all calibration is lost. VK7JH MMedit |
Thanks TassyJim, I have done what you said and don't have the error now. Still no change to LCD display on touching but I will look at that now. Again thanks for your advice. regards snarf |
