Local Time 09:32 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C addresses and CCS811
geodav
Posted: 02:32am 19 Mar 2020
Hi Gurus, have  been using the amazing Airquality monitor by Goeff Graham.
question: how would the I2C address change if 2 slave CCS811 modules were to be linked up to the same micromite in Goeff.S mmbasic touch screen program as published by Silicon chip Jan 2020 ?
Obviously I dont understand I2C that well as its my first use.
regards
George
CircuitGizmos
Posted: 02:12pm 19 Mar 2020
The CCS811 responds to two different I2C addresses based on a pin on the chip. Pin 1, named ADDR, is the selection pin that allows two alternate addresses to be selected:
If ADDR is low (0) the 7 bit I²C address for the chip is 0x5A (90 decimal)
If ADDR is high (1) the 7 bit I²C address for the chip is 0x5B (91 decimal)
geodav
Posted: 11:05pm 19 Mar 2020
Thanks for that CG,  I shall follow this protocol you outlined.
