Local Time 09:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Array Syntax
Phil23
Posted: 08:54pm 12 Mar 2020
Hi All,
Just trying to understand this a bit better; Arrays have always been a love/hate for me....
 I2C read &H5A, 0, 2, Baseline() ' read the register
 Baseline(2) = true
 VAR Save Baseline()
2nd line I assume sets a 1 in element 2,
3rd line saves the entire array.
But not quite clear in the 1st that addresses ().
Tried to think it out in DOS, but get a few unexpected results.
Particularly the 1st attempt to set element 0; Returning an error,
but then setting Ok after doing element 1.
Guess what I'm asking for is a better understanding of the usage of ().
Phil.
DOS MMBasic Ver 5.05.02
Copyright 2011-2019 Geoff Graham
> dim integer baseline(2)
> print baseline()
Error: Dimensions
> print baseline(0)
0
> baseline(0)=1
Error: Unknown command
> baseline(1)=2
> baseline(0)=1
> baseline(2)=3
> print baseline(0)
1
> print baseline(1)
2
> print baseline(2)
3
> print baseline()
Error: Dimensions
Edited 2020-03-13 06:56 by Phil23
Posted: 09:05pm 12 Mar 2020
The only time you use an array name without a dimension is when you pass the full array to a sub/function etc.
For normal use, you need the dimension or index
Depending on OPTION BASE, the first valid value for an index is 0 or 1
VAR SAVE and I2C are examples of passing the array name and therefore don't need the index
Phil23
Posted: 10:40pm 12 Mar 2020
Thanks Jim,
I'm still at a loss as to why baseline(0)=1 returned Unknown Command.
Just tried to reproduce it & I can't.
> print baseline()
Error: Dimensions
> print baseline(0)
0
> baseline(0)=1
Planning on modifying Geoff's Airqual code by adding some Console output via ESP-Link & HC-12 Comms for logging on the E64.
I am pretty sure it will see the sensor as New, & uncalibrated each time I load the updated code.
Assuming I can read all the saved VAR's & reload them at boot while I't testing the new code.
Phil.
