Forum Index : Microcontroller and PC projects : 4" SPI LCD for Raspberry Pie - calling matherp!!!
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043 |
These are the 4" SPI LCD's for the Pi, and I KNOW that matherp wrote a driver for this display to use it on the MM, but I can't seem to find it now. ![]() Perhaps someone - or matherp - can link me to the thread about these? They are Waveshare product, "4inch RPi LCD (A)" with the standard XPT2046 touch controller chip. My ones are "Rev2.0" if that helps. Smoke makes things work. When the smoke gets out, it stops! |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4381 |
Maybe this one matherp post I used google with site:www.thebackshed.com/forum XPT2046 matherp It found others so sorry if I've picked the wrong one. Maybe I should've tacked rpi onto the search? John Edited 2020-03-06 17:12 by JohnS |
| erbp Senior Member Joined: 03/05/2016 Location: AustraliaPosts: 195 |
I think this might be the thread you are after. Regards, Phil. |
@ JohnS: Thanks, but no. ![]() @ erpb: Yes, I think this is what I am after - thanks so much. I could not remember the LCD part number(ILI9481). Smoke makes things work. When the smoke gets out, it stops! |
