Local Time 09:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Interesting CMM Problem
Chopperp
Posted: 12:02pm 04 Mar 2020
FYI
I had a small software initialisation problem when my CMM program first starts up.
In one of my Library files which gets loaded, runs then gets unloaded, I have a line calling 3 subroutines :-
Gts1: Gts2: Gts3
The subroutines themselves just do some initial temperature measurements but some of the readings weren't correct. (They are called separately at different times in the main program & work fine).
I finally got around to looking at it today & found that the first subroutine wasn't doing anything. The others were.
Running it by itself worked as did placing it elsewhere in the program.
I changed the order of the routines to Gts2: Gts1: Gts3 & low & behold, Gts2 did nothing while Gts1 & Gts3 worked. Bit strange.
As a test, I put each on a separate line in the main program & that worked.
I then did the same in the Library file & that solved the problem.
Brian
ChopperP
Posted: 03:12pm 04 Mar 2020
In multi-statement lines,if the sub program names are in the first column with a colon directly following, they can get mistaken for line labels... e.g.
GTS1:GTS2:GTS3
isn't the same as
 GTS1:GTS2:GTS3
Check for that. I only ever put labels in column one. you could mitigate it by putting spaces either side of the colons which prevents them being interpreted as labels.
For this reason I tend to be pretty regimented in my formatting... I'd make a great Python programmer
Edited 2020-03-05 05:15 by CaptainBoing
Chopperp
Posted: 09:25pm 04 Mar 2020
Ah, I thought that there would be a logical answer. Forgot about labels.
Thanks.
Brian
ChopperP
Chopperp
Posted: 07:16am 05 Mar 2020
Just confirmed that:-
Gts1 :Gts2 :Gts3
works OK
Brian
ChopperP
