Local Time 09:59 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SHT21 Temp and Humidity sensor.
cs41
Posted: 09:31pm 22 Jan 2020
Has anyone successfully used the SHT 21 digital humidity and temp sensor with a Micromite.
The DHT series seem to have a problem where they are in high humidity environments for a considerable time and so wondering about using an SHT21 which seems to be a better sensor.
cs41
Posted: 10:39pm 22 Jan 2020
Not me personally, but if the SHT21 uses the same data protocol as the DHT21, then you should just be able to treat it as an DHT21 - even though it is not.
If you have one, I would just hook it up and query it using the DHT21 functions, and see if you get a sensible response.
I could be totally wrong with that assumption, but that would be where I would start.
Posted: 12:17am 23 Jan 2020
The SHT21 uses the same code as the HTU21
I think they all suffer from long time exposure to 100% humidity.
My current setup uses BME280 and SHT21. It has only been running for 12 months so too early to tell how long the sensors will last.
Code for SHT21:
 OPTION BASE 0
 DIM AS INTEGER TDATA(3)             '2 bytes of temp data plus CRC
 DIM AS INTEGER HDATA(3)             '2 bytes of humidity data plus CRC
 ON ERROR SKIP 1
 I2C OPEN 400,1000
 SETTICK 10000, doRead
 doRead
 DO
   k$ = INKEY$
 LOOP UNTIL k$ = "x" or k$ = "X"
 I2C CLOSE
END
SUB doRead
 HTU21D
 PRINT TIME$;"   ";STR$(Temperature,4,1);"c  ";STR$(RELHUMID,4,0);"%   ";STR$(RFHUMID,4,0);"%"
END SUB
SUB HTU21D                         'TEMPERATURE SENSOR, This is the SUB routine for talking to the HTU21
 I2C WRITE &H40,0,1,&HF3            'HTU21 addr= 40 hex, request temp = F3 hex
 PAUSE 60
 I2C READ &H40,0,3,TDATA()          'reads temperature
 TEMP1!=TDATA(0)*256 + TDATA(1)      'combines both data bytes
 IF checkCRC(TEMP1!,TDATA(2)) THEN
   Temperature = -999
 ELSE
   TEMP1! = TEMP1! AND &hFFFC ' mask off status bits
   Temperature=(175.72*(TEMP1!/65536))-46.85 'HTU21 formula for temp
 ENDIF
 TEMPCOMP= (Temperature-25)*0.15           'for RH temp comp
 I2C WRITE &H40,0,1,&HF5            'request humidity
 PAUSE 30
 I2C READ &H40,0,3,HDATA()
 HUMIDACT!=HDATA(0)*256 + HDATA(1)
 IF checkCRC(HUMIDACT!,HDATA(2)) THEN
   RELHUMID= -999
 ELSE
   HUMIDACT! = HUMIDACT! AND &hFFFC ' mask of status bits
   RELHUMID= ((HUMIDACT!/65536)*125)-6 ' measured humidity
   RFHUMID= RELHUMID + TEMPCOMP         'Temperature compensated humidity
 ENDIF
END SUB
FUNCTION checkCRC(message_from_sensor, check_value_from_sensor)
 ' Give this function the 2 byte message (measurement) and the check_value byte from the HTU21D
 ' If it returns 0, then the transmission was good
 LOCAL INTEGER i, remainder, divisor
 divisor = &h988000 'This is the 0x0131 polynomial shifted to farthest left of three bytes
 remainder = message_from_sensor << 8 'Pad with 8 bits because we have to add in the check value
 remainder = remainder OR check_value_from_sensor ' Add on the check value
 FOR i = 0 TO 15 'Operate on only 16 positions of max 24. The remaining 8 are our remainder and should be zero when we're done.
   IF (remainder AND (1 << (23 - i)) )  THEN ' Check if there is a one in the left position
     remainder = remainder XOR divisor
   ENDIF
   divisor = divisor >> 1 ' Rotate the divsor max 16 times so that we have 8 bits left of a remainder
 NEXT i
 checkCRC = remainder
END FUNCTION
Search the forum for SHT21.
There was a comparison of various sensors a few years ago.
palcal
Posted: 12:58am 23 Jan 2020
I have been using HTU21D and have found them much more reliable that DHT22. I have had two running for about a year with no problems. The code I use is...
Sub HTU21D                    'This is the SUB routine for talking to the HTU21
 I2C write &H40,0,1,&HF3            'HTU21 addr= 40 hex, request temp = F3 hex
 Pause 100
 I2C read &H40,0,2,TDATA()                      'reads temperature
 TEMP1=TDATA(0)*256 + TDATA(1)                  'combines both data bytes
 I2C write &H40,0,1,&HF5                        'request humidity
 Temperature=(175.72*(TEMP1/65536))+ -46.85     'HTU21 formula for temp
 TEMPCOMP= -.15*(25-ROOF)                       'for RH temp comp
 Pause 50
 I2C read &H40,0,2,HDATA()
 HUMIDACT=HDATA(0)*256 + HDATA(1)
 RELHUMID= ((HUMIDACT/65536)*125)+ -6      ' measured humidity
End Sub
I must say this is not my code, DaveC166 gave it to me.
Edited 2020-01-23 16:52 by palcal
cs41
Posted: 09:47pm 23 Jan 2020
Thanks everyone for helpful comments.
Will try these and see how they work in our application.
many thanks for helpful comments as always.
cs41
DaveC166
Posted: 08:20pm 25 Jan 2020
I gave up on Ebay sourced DHT22's 3 years ago, due to the erratic humidity readings especially when the temperature was under 20 deg C. The 8 DHT22's were from 3 different sellers
The Ebay sourced HTU21D's have been working without any glitches for three years.
Tassyjim's code solves the only thing i couldnt workout, how to use the CRC checksum.
The only slight hassle with HTU21D modules is the need for a dust cover over the port in the chip
palcal
Posted: 09:19pm 28 Jan 2020
Well I should have kept my mouth shut, my outdoor HTU21D is reading 119%. It has been very wet here lately, over 250mm. of rain in the last 3 days. Don't know if that has caused the trouble, the sensor is well protected.
@DaveC166  What do you mean by a dust cover, wouldn't that affect the reading?
palcal
Posted: 09:25pm 28 Jan 2020
I see in the Datasheet there is an (F) version of the chip that has the dust cover factory fitted.
Posted: 09:42pm 28 Jan 2020
  palcal said  Well I should have kept my mouth shut, my outdoor HTU21D is reading 119%. It has been very wet here lately, over 250mm. of rain in the last 3 days. Don't know if that has caused the trouble, the sensor is well protected.
It might recover in time when the humidity drops.
Try bringing it inside for a few days. There is a heater built into them which can be used to see if the humidity sensor is working.
A bit of heat should lower the humidity.
Luck they are relatively cheap to buy.
palcal
Posted: 01:54am 29 Jan 2020
I'll bring it in when it stops raining, I have a spare.
palcal
Posted: 08:44pm 05 Feb 2020
I bought one of these, may be better for my outdoor sensor.
HTU21D
DaveC166
Posted: 09:12pm 06 Feb 2020
HI Pacal,
The HTU21D modules are supposed to have a dust proof foam cover over the sample port in the chip, as dust and moisture will effect the accuracy of the readings. I screwed up one HTU21D by exposing it to steam. The module did work correctly after it dried out. I have ordered a couple of the protective case Htu21D's as per your link. the mounting holes will come in handy. I presume it is best to mount them so the filter is vertical ?.
