Local Time 10:26 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MICROMITE PLUS SD PROBLEM
OA47
Posted: 06:41am 24 Dec 2019
I have been playing with a project on the mm plus E64 where I came to a problem accessing a small database on the SD card. The problem was that within the program I could access the file (32K) and count the records then when I close the file and re-open it later in the program I got an error of file not open. Looked at the MM build and it showed ver 5.03.02 so I decided to update to version 5.05.02. This all went Ok but now I cannot load the program as when I type LOAD "PROGRAM.BAS" I get Error: Invalid in a program. And this occurs no matter which file I try to load.
Any guidance would be much appreciated.
OA47
SWA-Guy
Posted: 01:48pm 24 Dec 2019
I have the same problem with my Explore 100 and ver 5.05.02.
If I go back to ver 5.05.01 the "LOAD" command works correcly.
I use the sd-card slot from the SSD1963 5" lcdpanel.
Here my configuration:
OPTION BAUDRATE 230400
OPTION COLOURCODE ON
OPTION DISPLAY 24, 66
OPTION LCDPANEL SSD1963_5, LANDSCAPE, 48, 6
OPTION TOUCH 1, 40, 39
GUI CALIBRATE 1, 113, 3826, 2086, -1310
OPTION SDCARD 47
OPTION LCDPANEL CONSOLE
Merry chrismas from Germany.
Posted: 08:48pm 24 Dec 2019
You have found a bug.
Geoff will probably be thinking "bah humbug!"
The LOAD command was changed in V5.05.02 to create an error when trying to LOAD from within a program but it appears that things went astray a bit.
From the change log:
"Trying to use LOAD "file" in a program will now generate an error. LOAD "file", R is
unchanged can be used both in a program and at the command prompt."
I can confirm that LOAD "myprog.bas" from the command prompt does raise an error.
LOAD "myprog.bas" ,R does load and run as expected.
So, LOAD "myprog.bas" ,R followed by ctrl-C will get you there for now.
OA47
Posted: 09:04pm 24 Dec 2019
Tassy Jim, thank you for the xmas present, I can now continue with the project over the next couple of days I have off.
Merry Xmas Shedders
OA47
OA47
Posted: 10:23pm 24 Dec 2019
This one may slow me down a bit. When reading the data base with LINE INPUT, CC$ if the string has leading zeros then they are ommitted.
Database entry 0000GOSH
LINE INPUT READS CC$="GOSH"
Curses, foiled again.
OA47
Posted: 11:18pm 24 Dec 2019
Bummer, and there I was thinking that V5.05.02 was near perfect.  OK, after Christmas I will look into these reports.
Thanks,
OA47
Posted: 11:31pm 24 Dec 2019
Thanks Geoff, sorry to interrupt your Christmas. I can wait until the new year. I might be able to modify the database to change the leading zeros. By the way the leading zeros in the string from the file is apparent in 5.03.
OA47
Posted: 01:31am 25 Dec 2019
Are the leading zeros chr$(0) or chr$(48)- "0"
OA47
Posted: 02:38am 25 Dec 2019
Jim, the string is saved as "00000HG1LH000V" but reads back in as "HG1LH000V".
I have just been thru the database and changed each "0" to "O" and I will see if I can use it.
OA47
Posted: 04:21am 25 Dec 2019
This works for me:
  Quote    OPEN "my.db" FOR output AS #2
FOR n = 1 TO 10
PRINT #2, "00000HG1LH000V"
NEXT n
CLOSE #2
 OPEN "my.db" FOR INPUT AS #3
FOR n = 1 TO 10
LINE INPUT #3, txt$
PRINT txt$
NEXT n
CLOSE #3
I'm supposed to be having my after dinner nap about now...
OA47
Posted: 06:40am 30 Dec 2019
Any thoughts on this one?
[247] MID$(RP$,J,1)="1"
Error: MID is not declared
> ? J
5
> ? mm.ver
5.0502
Posted: 07:01am 30 Dec 2019
MID$() cannot be used as a command (ie, be assigned a value like PIN()).
Some BASICs (I cannot remember which) did allow this but not MMBasic.
OA47
Posted: 07:13am 30 Dec 2019
Thanks Geoff I shall soldier on.
OA47
Posted: 07:46am 30 Dec 2019
Someting like this:
  Quote    a$ = "fred,wilma"
 j =
5
 n$ =
" and "
 b$ = replaceStr$(a$,J,
1,n$)
PRINT a$
PRINT b$
FUNCTION replaceStr$(src$,st,n,newStr$)
 replaceStr$=
LEFT$(src$,st-1)+newStr$+MID$(src$,st+n)
END FUNCTION
OA47
Posted: 08:46am 30 Dec 2019
Thanks again Jim. I replaced the string with a number that held the appropriate values.
OA47
Posted: 08:51am 30 Dec 2019
  Geoffg said  MID$() ... as a command...
Some BASICs (I cannot remember which) did allow this...
Just off the top of me 'ead:
I think all the MS basics from GW onward supported MID$ as a statement (QB and VB defo) as well as Mallard Basic; which was used on the CPCs and the various CPM offerings from Amstrad (i.e. for Speccy+3, PCW etc). There was also a version of this for MSDOS.
It is a rare enough requirement and easy to work round.
all the best
Edited 2019-12-30 20:20 by CaptainBoing
