Local Time 16:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Audible Alarm For MM170
Andrew_G
Posted: 02:28am 10 Nov 2019
My BBQ Probe (see here) is progressing well with the probe temperature and timers being shown on a MM170 LCD BackPack. I flash the screen red as the probe approaches the set temperature etc.
What I am lacking is an audible alarm.
Do any of you have any tried "solutions"? (this will have other applications too). (And yes I know the MM+ can do better).
Preferably loud enough and low enough frequency for my aged hearing (and even with adjustable frequency and volume? - either in the circuit or via setup on the LCD).
I have tried fixed frequency buzzers (with a trimpot to adjust volume - too high a frequency for my ears) and allegedly PWM controllable ones for Arduino (much too quiet).
Many thanks,
Andrew
BrianP
Posted: 05:26am 10 Nov 2019
  Andrew_G said  Hi,
Many thanks,
Andrew
You need to cycle through a range of frequency - like police / ambo sirens. You also need an amp to boost the PWM - there are heaps of very small single board / chip possibilities out there, 5-12v powered. You could then use this to drive a piezo sounder thingy - some of these are really loud (you need a passive one, not one of the fixed frequency ones).
Also there are small single board police siren emulators - just feed them the volts & away they go. Jaycar or Altronics should have them. Although letting the micro do the PWM would let you choose the best range that suits.
B
Andrew_G
Posted: 03:39am 11 Nov 2019
Brian,
Many thanks! I paid my local Jaycar shop a visit and settled on.
It is a magic little amplifier that does the trick for me.
I also bought a number of passive buzzers to play with and this speaker .
Now I can now use the PWM command to get notes etc.
All buzzers/speaker are loud enough for an alarm. I might add a trim-pot for volume control.
I'd make the following comments about the amplifier:
- it is stereo (I only need one channel)
- it is really small and inexpensive ~Au$5
- its pinouts are spaced for cable connections, not pins/headers, but I was able to cheat and force the ones I needed to standard headers for breadboard etc.
- it has a pin "SW" for "Switch" which, when grounded, turns the amplifier off - I'll use that with touch control for "Mute".
Cheers,
Andrew
Andrew_G
Posted: 05:04am 11 Nov 2019
I've spent an hour or so playing with alarm sounds on my MM170.
(The dog doesn't like the high pitched ones.)
Here is what I have so far (80:20 rule).
 For I = 1 to 50   'Just a loop so you get the idea
   TimerOld = Timer
   PWM 2, 300, 10  'PWM 2 (is Pin # 26), Frequency, DutyCycle
   Do:Loop While Timer < TimerOld + 500  '500 is the duration of the "note" in mS
   TimerOld = Timer
   PWM 2, 600, 10
 Next I
 PWM 2, STOP     'Otherwise it keeps playing the last "note"
Do any of you have any snippets to suggest?
Is there a "Library" of MM sounds or even ditties?
(I'm really looking for a bit of friendly competition here . . .)
Cheers,
Andrew
Edited 2019-11-11 15:07 by Andrew_G
twofingers
Posted: 04:38pm 11 Nov 2019
  Andrew_G said  Do any of you have any snippets to suggest?
I'm using "bird" and "siren" for a small piezo buzzer:
Option explicit
Dim T1 'temperature from a DS18B20
Dim j  'loop counter
const threshold=22
 TEMPR START 3, 3
 T1= TEMPR(3)
 Print T1
 If T1 <threshold Then
    For j = 1 To 5
      bird 'or siren
    Next j
    PWM 2, STOP
    Print "L"
    Pause 2000
 EndIf
Loop
Sub bird
Local integer f1,f2
    For f1 = 440 To 3000 Step 200
      PWM 2,f1,50
      Pause 10
    Next f1
    For f2 = f1 To 440 Step -200
      PWM 2,f2,50
      Pause 10
    Next f2
End Sub
Sub siren
Local integer f1,f2
      PWM 2,f1,50
      Pause 10
    Next f1
      PWM 2,f2,50
      Pause 10
    Next f2
End Sub
Andrew_G
Posted: 10:05pm 11 Nov 2019
Thanks Twofingers,
Very good - I will pinch them if I may??
OK Shedders - any other snippets?
Your code also helped me understand:
- PAUSE actually does pause the execution (I put "PRINT TIMER" before and after and then in a second test removed the Pause - sounded very different). From my reading of the manual I expected the "tone" to not stop but to continue until the next "PWM" command (eg as occurs with a ^C).
Hence my clumsy workaround of " Do:Loop While Timer < TimerOld + 500". I'll change to PAUSE from now on.
- I don't need a trimpot for adjusting volume - just alter the dutycycle parameter!
- TEMPR START to set the precision of the DS18B20 reading (I have, without thinking, been using the default - OK for some applications but not all).
Thanks again,
Andrew
Edited 2019-11-12 11:58 by Andrew_G
twofingers
Posted: 11:36am 12 Nov 2019
Hi Andrew,
  Quote  Very good - I will pinch them if I may??
sure, it is posted for that.
I hope, you will get more code snippets.
Michael
Turbo46
Posted: 12:13am 13 Nov 2019
You might like to have a look at this post for some sounds.
Edit: Another approach could be to write a routine that imitates the Maximite SOUND or TONE commands and pinch some sounds from Maximite games?
Edited 2019-11-13 10:34 by Turbo46
