Local Time 10:47 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : H7 PWM question
Tinine
Posted: 10:11am 09 Nov 2019
From the manual 2019-06-25_212755:
Eight PWM Channels
Minimum frequency is 1Hz, maximum is 24MHz. Duty cycle and frequency accuracy will depend on
frequency. The frequency can be any value of 240,000,000/n.
This has recently changed from 200,000,000 (from 400MHz to 480MHz?)
Would this be, say 270,000,000 for 540MHz, etc.? (figuring out PWM-DAC resolution).
If this is the case, might be better worded as nominal CPU freq/2 (?)
